Name and number in the name of the exported dxf file
J.J.Kucharczyk
J.J.Kucharczyk
Thank you in advance for your understanding. I am completely new to iLogic.
For the last 2 weeks I have been trying to obtain the code that exports the design to dxf files for laser cutting.
I have modified several codes and have come up with one that works almost perfect.
I would like the DXF file name to be in the format:
(Thickness) - (Quantity) - (File name) - (material type).dxf
At the moment there is only the name and the extension.
Below is the code I am using.
What should I change?
Thank you for any advice.
Dim oDoc As Document
oDoc=ThisDoc.Document
Dim docFile As Document
For Each docFile In oDoc.AllReferencedDocuments
ThisApplication.Documents.Open(docFile.FullFileName,True)
Dim partDoc As PartDocument
partDoc=ThisApplication.ActiveDocument
If partDoc.SubType="{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oCompDef As SheetMetalComponentDefinition
oCompDef=partDoc.ComponentDefinition
Dim oDataIO As DataIO
oDataIO=oDoc.ComponentDefinition.DataIO
If oCompDef.HasFlatPattern=False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String = "FLAT PATTERN DWG?AcadVersion=2000" _
+"&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL;IV_FEATURE_PROFILES_DOWN" _
+"&SimplifySplines=True" _
+"&LINEAR TOLERANCE=0.010" _
+"&MergeProfilesIntoPolyline=True" _
+"&RebaseGeometry=False" _
+"&TrimCenterlines=True"
Dim invPropSets As PropertySets
invPropSets=partDoc.PropertySets
Dim invPropSet As PropertySet
invPropSet=invPropSets.Item("Design Tracking Properties")
Dim invPartNumiProp As Inventor.Property
invPartNumiProp = invPropSet.Item("Part Number")
Dim invPartQty As Inventor.Property
invPropSet2 = invPartQty
Dim sFname As String
sFname=ThisDoc.Path &"\"& invPartNumiProp.Value & SheetMetal.GetActiveStyle &".dxf"
oCompDef.DataIO.WriteDataToFile(sOut,sFname)
oCompDef.FlatPattern.ExitEdit
If partDoc.ComponentDefinition.IsiPartFactory Or
partDoc.ComponentDefinition.IsiPartMember Then
partDoc.Save()
Else
partDoc.Close
Next
Andrii_Humeniuk
Hi @J.J.Kucharczyk . I rewrote the logic of your rule. Please try to see if the rule works normally.
Private Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oBOMView As BOMView = GetBOMpartsOnly(oDef.BOM)
	For Each oRow As BOMRow In oBOMView.BOMRows
		Dim oRowDef As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
		Dim partDoc As PartDocument = oRowDef.Document
			Dim oCompDef As SheetMetalComponentDefinition = oRow.ComponentDefinitions.Item(1)
			Dim oDataIO As DataIO = oDoc.ComponentDefinition.DataIO
				oCompDef.Unfold
			Else
			Dim invPropSets As PropertySets = partDoc.PropertySets
			Dim invPropSet As PropertySet = invPropSets.Item("Design Tracking Properties")
			Dim invPartNumiProp As Inventor.Property = invPropSet.Item("Part Number")
			Dim dThick As Double = oCompDef.Thickness.Value
			Dim iQ As Integer = oRow.TotalQuantity
			Dim sName As String = partDoc.DisplayName
			Dim sMaterial As String = partDoc.ActiveMaterial.DisplayName
			Dim sFname As String = ThisDoc.Path & "\" & dThick & " - " & iQ & " - " & sName & " - " & sMaterial &".dxf"
'			Dim sFname As String = ThisDoc.Path & "\" & invPartNumiProp.Value & SheetMetal.GetActiveStyle &".dxf"
				partDoc.Save()
	Next
End Sub
Private Function GetBOMpartsOnly(ByVal oBOM As BOM) As BOMView
	Dim oLanguageBOM As String
	Select Case ThisApplication.LanguageCode
	Case "en-US"
		oLanguageBOM = "Parts Only"
		Exit Function
	End Select
	If oBOM.PartsOnlyViewEnabled = False Then
		oBOM.PartsOnlyViewEnabled = True
	Return oBOM.BOMViews.Item(oLanguageBOM)
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
J.J.Kucharczyk
Thanks for the quick response.
A message like this is occurring.
Andrii_Humeniuk
I made a mistake on line 50. It should work fine now. Note that the thickness is written in cm, if you need other units then change line 29.
Private Sub Main()
		If partDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
				oCompDef.Unfold
			Else
				partDoc.Save()
	Next
End Sub
	Case "en-US"
	Case Else
		Exit Function
	End Select
End Function
J.J.Kucharczyk
Thank you Andrii.
Now have :
Error on line 14 in rule: NY Assebly to dxf, in document: Test DXF ny.iam
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Under more info:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.FlatPattern.Edit()
at ThisRule.Main() in external rule: NY Assebly to dxf:line 14
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Andrii_Humeniuk
This code works perfectly for me, you start having problems when editing the FlatPatternI added the opening of the document, maybe it will help you. Please check the following code:
Private Sub Main()
			Dim openDoc As Document = ThisApplication.Documents.Open(partDoc.FullDocumentName, True)
			If Not oCompDef.HasFlatPattern Then
				oCompDef.Unfold()
			Else
				oCompDef.FlatPattern.Edit()
			Dim sPath As String = System.IO.Path.GetDirectoryName(partDoc.FullFileName)
			Dim sFname As String = sPath & "\" & dThick & " - " & iQ & " - " & sName & " - " & sMaterial &".dxf"
			oCompDef.FlatPattern.ExitEdit()
			If partDoc.ComponentDefinition.IsiPartFactory Or partDoc.ComponentDefinition.IsiPartMember Then
				partDoc.Save()
			openDoc.Close()
	Next
End Sub
	Case "en-US"
	Case "ru-RU"
		oLanguageBOM = "Только детали"
	Case Else
		Exit Function
	End Select
End Function
J.J.Kucharczyk
I'm sorry that I'm answering week later, but I was on hollidays 🙂
Thanks a lot! I will check all of your codes ASAP.
Once again thnak you!
EDIT:
Code from message 4 works fine 🙂 THANK YOU!!!!!!!
Thickness displayed for example for 4mm was 0.4 , so I just  added the multiplier (*10).
All the best!
