my.resources vb.net to c#
^_^clovis^_^
^_^clovis^_^
Hello all,
I hope that everyone is OK during this Covid period.
I'm trying to translate  a vb.net project into a c# one. I don't see how to translate "my.resources" as showed here after in my vb.net project:
' Sample to illustrate creating a button definition.
            Dim largeIcon As IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.Pic_large)
Any help would be greatly appreciated!
thanks
yan.gauthier
System.Drawing.Icon DimGenIcon = new System.Drawing.Icon(this.GetType(), "IconFile.ico");
All you have to do is set your IconFile.ico as EmbeddedRessource
yan.gauthier
^_^clovis^_^
Hello yan.gauthier
That's also what I did after some search on the internet. I found great guideline from Smallguru.
Thanks to him.
http://www.ar-cad.com/smallguru/2008/08/develop-autodesk-inventor-addin-using-csharp-part-1/
I was looking for the same approach as vb.net with just
my.resources... I found it elegant. I guess there isn't a 1 on 1 translation.
Thanks for you support!
yan.gauthier
If you wish to do a 1 for 1 translation, some samples uses the Microsoft.VisualBasic.Compatibility.VB6 namespace, but it is not recommended as it is legacy. Instead, you could implement the following class
  internal class AxHostConverter : AxHost
        private AxHostConverter() : base("") { }
        static public stdole.IPictureDisp ImageToPictureDisp(Image image)
            return (stdole.IPictureDisp)GetIPictureDispFromPicture(image);
        static public Image PictureDispToImage(stdole.IPictureDisp pictureDisp)
            return GetPictureFromIPicture(pictureDisp);
then, you should be able to translate
into
stdole.IPictureDisp largeIcon = AxHostConverter.ImageToPictureDisp(Properties.Resources.Pic_large)
^_^clovis^_^
Hello Yan,
Thank you very much! that'll do!
