My first VB.Net add-in will not load
I'm just starting out with Visual Basic 2008
Express.  I've read Brian Ekins' white paper titled "Taking the Step from
VBA Macros to Add-Ins" top to bottom and to the best of my knowledge I've
followed each and every step outlined there exactly.  My add-in compiles
and registers with no errors nor warnings.  It appears
in Inventor's list of add-ins, but is Unloaded and will not Load.
This is driving me absolutely crazy, so can someone PLEASE tell me what the
hell I'm doing wrong?
Below is the code that appears in the
CenterAlignAddInServer.vb class.  Note that "objInventor" is declared as a
global variable in a module named Global.vb.
Imports
face=Verdana color=#000000> Inventor
Imports
System.Runtime.InteropServices
Imports
face=Verdana color=#000000> Microsoft.Win32
Namespace
face=Verdana color=#000000> CenterAlign
<ProgIdAttribute(
size=2>"CenterAlign.CenterAlignAddInServer"
face=Verdana color=#000000>), _
GuidAttribute(
size=2>"20a8f692-d9cd-4747-bdc7-5d2233da828f"
face=Verdana color=#000000>)> _
Public
size=2>
Class
face=Verdana color=#000000> CenterAlignAddInServer
Implements
size=2>
Inventor.ApplicationAddInServer
size=2>Private
WithEvents
size=2> objCenterAlignButton
As
size=2> Inventor.ButtonDefinition
Private Declare Function
SetParent Lib "user32" Alias "SetParent" (ByVal hWndChild As Int32, ByVal
hWndNewParent As Int32) As Int32
#Region
face=Verdana>
size=2>"ApplicationAddInServer Members"
Public
size=2>
Sub Activate(
size=2>ByVal
addInSiteObject
size=2>As
Inventor.ApplicationAddInSite,
size=2>ByVal
firstTime As
size=2>
Boolean)
size=2>Implements
color=#000000> Inventor.ApplicationAddInServer.Activate
Dim
size=2> strAddInGUID
As
size=2>String
Dim
size=2> objCommandBar
As
size=2> Inventor.CommandBar
' This method is called
by Inventor when it loads the AddIn.
' The AddInSiteObject
provides access to the Inventor Application object.
size=2>
' The FirstTime flag
indicates if the AddIn is loaded for the first time.
size=2>
' Initialize AddIn
members.
objInventor =
addInSiteObject.Application
strAddInGUID =
face=Verdana>"{" &
CType
size=2>(System.Attribute.GetCustomAttribute(
size=2>GetType
(CenterAlignAddInServer),
size=2>GetType
(GuidAttribute)), GuidAttribute).Value &
objCenterAlignButton =
objInventor.CommandManager.ControlDefinitions.AddButtonDefinition(
face=Verdana>"CenterAlign",
"CenterAlignButton",
CommandTypesEnum.kEditMaskCmdType, strAddInGUID,
size=2>"CenterAlign"
, "Aligns parallel
centerlines"
color=#000000>)
If
size=2> firstTime
Then
objCommandBar =
objInventor.UserInterfaceManager.CommandBars(
color=#000000 size=2>"DLxDrawingAnnotationPanelCmdBar"
color=#000000>objCommandBar.Controls.AddButton(objCenterAlignButton)
End
size=2>
If
objCommandBar =
size=2>Nothing
End
size=2>
Sub
Public
size=2>
Sub Deactivate()
size=2>Implements
Inventor.ApplicationAddInServer.Deactivate
color=#000000>Marshal.ReleaseComObject(objInventor)
objInventor =
size=2>Nothing
size=2>Nothing
color=#000000>System.GC.WaitForPendingFinalizers()
System.GC.Collect()
End
size=2>
Sub
Public
size=2>
ReadOnly
size=2>Property
Automation()
size=2>As
Object
Implements
Inventor.ApplicationAddInServer.Automation
' This property is
provided to allow the AddIn to expose an API
' of its own to other
programs. Typically, this would be done by
' implementing the
AddIn's API interface in a class and returning
' that class object
through this property.
color=#000000>Get
Return
size=2>
Nothing
End
size=2>
Get
End
size=2>
Property
Public
size=2>
Sub ExecuteCommand(
size=2>ByVal
commandID As
size=2>
Integer)
size=2>Implements
color=#000000> Inventor.ApplicationAddInServer.ExecuteCommand
' Note:this method is
now obsolete, you should use the
' ControlDefinition
functionality for implementing commands.
End
size=2>
color=#000000>Sub
#End
color=#000000>Region
#Region
face=Verdana> "COM
Registration"
' Registers this class
as an AddIn for Inventor.
' This function is
called when the assembly is registered for COM.
<ComRegisterFunctionAttribute()>
_
Public
size=2>
Shared
size=2>Sub
Register(ByVal
size=2> t
As
face=Verdana color=#000000> Type)
Dim
size=2> clssRoot
As
face=Verdana color=#000000> RegistryKey = Registry.ClassesRoot
Dim
size=2> clsid
As RegistryKey =
Nothing
Dim
size=2> subKey
As RegistryKey =
Nothing
color=#000000>Try
clsid =
clssRoot.CreateSubKey(
size=2>"CLSID\"
AddInGuid(t))
clsid.SetValue(
face=Verdana>Nothing,
"CenterAlign"
subKey =
clsid.CreateSubKey(
size=2>"Implemented
Categories\{39AD2B5C-7A29-11D6-8E0A-0010B541CAA8}"
subKey.Close()
subKey =
clsid.CreateSubKey(
size=2>"Settings"
color=#000000>)
subKey.SetValue(
face=Verdana>"AddInType",
"Standard"
subKey.SetValue(
face=Verdana>"LoadOnStartUp"
size=2>,
"1"
color=#000000>'subKey.SetValue("SupportedSoftwareVersionLessThan",
subKey.SetValue(
face=Verdana>
size=2>"SupportedSoftwareVersionGreaterThan"
size=2>"12.."
color=#000000>)
color=#000000>'subKey.SetValue("SupportedSoftwareVersionEqualTo",
color=#000000>'subKey.SetValue("SupportedSoftwareVersionNotEqualTo",
color=#000000>'subKey.SetValue("Hidden", "0")
color=#000000>'subKey.SetValue("UserUnloadable", "1")
size=2>
subKey.SetValue(
face=Verdana color=#000000 size=2>"Version"
face=Verdana color=#000000>, 0)
subKey.Close()
subKey =
clsid.CreateSubKey(
size=2>"Description"
color=#000000>)
subKey.SetValue(
"CenterAlign"
Catch
size=2> ex
As
face=Verdana color=#000000> Exception
color=#000000>System.Diagnostics.Trace.Assert(
color=#000000 size=2>False
color=#000000>)
color=#000000>Finally
If
size=2>
Not subKey
size=2>Is
Nothing
Then
color=#000000> subKey.Close()
If
size=2>
Not clsid
size=2>Is
Nothing
Then
color=#000000> clsid.Close()
If
size=2>
Not clssRoot
size=2>Is
Nothing
Then
color=#000000> clssRoot.Close()
End
size=2>
Try
End
size=2>
Sub
' Unregisters this class
' This function is
called when the assembly is unregistered.
<ComUnregisterFunctionAttribute()>
_
Public
size=2>
Shared
size=2>Sub
Unregister(ByVal
size=2> t
As
Dim
size=2> clssRoot
As
Dim
size=2> clsid
As RegistryKey =
Nothing
color=#000000>Try
clssRoot =
Microsoft.Win32.Registry.ClassesRoot
clsid =
clssRoot.OpenSubKey(
size=2>"CLSID\"
+ AddInGuid(t),
size=2>True
color=#000000>)
clsid.SetValue(
color=#000000>)
clsid.DeleteSubKeyTree(
face=Verdana color=#000000 size=2>"Implemented
face=Verdana color=#000000 size=2>"Settings"
face=Verdana color=#000000 size=2>"Description"
color=#000000>Catch
If
size=2>
Not clsid
size=2>Is
Nothing
Then
If
size=2>
Not clssRoot
size=2>Is
Nothing
Then
End
size=2>
Try
End
size=2>
Sub
' This property uses
reflection to get the value for the GuidAttribute attached to the
class.
Public
size=2>
Shared
size=2>ReadOnly
Property
size=2> AddInGuid(
ByVal t
size=2>As
Type) As
String
color=#000000>Get
Dim
size=2> guid
As
size=2>String
size=2>""
color=#000000>Try
Dim
size=2> customAttributes()
As
Object =
t.GetCustomAttributes(
GetType
size=2>(GuidAttribute),
False
size=2>)
Dim
size=2> guidAttribute
As GuidAttribute =
CType
color=#000000>(customAttributes(0), GuidAttribute)
guid =
face=Verdana>"{" +
guidAttribute.Value.ToString() +
size=2>"}"
AddInGuid = guid
End
size=2>
Try
End
size=2>
Get
End
size=2>
color=#000000>Property
#End
color=#000000>
size=2>Region
size=2>Private
Sub
objCenterAlignButton_OnExecute(
ByVal
Context
As Inventor.NameValueMap)
Handles
color=#000000> objCenterAlignButton.OnExecute
Dim
size=2> objCenterAlignDialog
As
New
color=#000000> CenterAlignDialog
color=#000000>SetParent(objCenterAlignDialog.Handle.ToInt32,
objInventor.MainFrameHWND)
objCenterAlignDialog.Show()
End
size=2>
Sub
End
size=2>
color=#000000>Class
End
color=#000000>
size=2>Namespace
Well, I found the problem and apparently it's an
old one.
The problem was the location of the
.dll.  I moved it from its original location (inside My Documents) to a
folder beneath Inventor's \bin folder and viola, it works.  I thought I
remembered reading that this problem was resolved a long time ago?
brian r.
iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">inventor
specialist
This should no longer be an issue. Is this a test
on your development machine, or are you testing the dll on another machine? If
on another machine, did you register the add-in on that machine using the
/codebase switch?
32 or 64 bit O/S's?
In the properties page for the project, is
"Register form COM interop" checked? (It should be if you used the Inventor
Add-in project template.) Can you debug the add-in?
an old one.
ago?
brian
r. iwaskewycz
specialist
title="http://www.corefurnace.com/ CTRL + Click to follow link"
href="http://www.corefurnace.c...
It's a test on a development
machine.
64-bit OS.
I don't see "Register form COM interop" anywhere
(maybe because I'm using VB2008 Express?).
No, I CANNOT debug the add-in (keep seeing "No
symbols have been loaded for this document.")  Starting to anger
me.
brian r.
iwaskewycz
specialist
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">core furnace
systems
Try the following:
Debugging with VS Express Editions (See Brian's
reply)
Registering 64 bit add-ins (I assume you will need to do this on your
dev machine as well if you want it to run outside the dev environment)
Get your company to spring for the Standard edition
of Visual Studio, worth the few bucks.
HTH
machine.
64-bit OS.
anywhere (maybe because I'm using VB2008 Express?).
me.
brian
r. iwaskewycz
specialist
systems
