My first try at VBA, sometimes its really slow....
12:50 AM
I won't take a lot of credit for this code as its just pieced together from other codes found here on the forum...
Sometimes its working really slow, can it be made shorter or faster in any way? I dont have a clue of what Im doing, but the code works... 🙂
And one other thing is it possible to get it to create flat pattern so i dont have to?
some of the text is in Norwegian...
Sub LaserTimeCalc() Dim oApp As Inventor.Application Dim oDoc As Inventor.Document Set oApp = GetObject(, "Inventor.Application") If oApp.ActiveDocumentType = kDrawingDocumentObject Then Set oDoc = oApp.ActiveDocument Else: If TypeOf oApp.ActiveEditObject Is Sketch Then Exit Sub Set oDoc = oApp.ActiveEditObject End If Dim oSMDef As SheetMetalComponentDefinition Set oSMDef = oDoc.ComponentDefinition 'if flatpattern doesnt exist If oSMDef.FlatPattern Is Nothing Then MsgBox "Create Flatt Pattern First." Exit Sub End If Dim oFace As Face Set oFace = oSMDef.FlatPattern.TopFace Dim Laser As Double TotalLength = 0 Dim oEdge As Edge For Each oEdge In oFace.Edges Dim oEvaluator As CurveEvaluator Set oEvaluator = oEdge.Evaluator Dim minparam As Double Dim maxparam As Double Call oEvaluator.GetParamExtents(minparam, maxparam) Dim length As Double Call oEvaluator.GetLengthAtParam(minparam, maxparam, length) Laser = Laser + length Next Dim oCustomPropSet As PropertySet Set oCustomPropSet = oDoc.PropertySets.Item("User Defined Properties") ' Check to see if the property already exists. On Error Resume Next Dim oCustomProp As Property Set oCustomProp = oCustomPropSet.Item("LaserTid") If Err Then ' It doesn't exist, so create it. Set oCustomProp = oCustomPropSet.Add(Laser, "LaserTid") End If 'Factor for cutting time calculation by thickness Select Case oSMDef.thickness.Value Case 0.02 To 0.25 Laserparam = 0.000041666 Case 0.26 To 0.35 Laserparam = 0.000048333 Case 0.36 To 0.45 Laserparam = 0.000051666 Case 0.46 To 0.55 Laserparam = 0.0000616666 Case 0.56 To 0.75 Laserparam = 0.000075 Case 0.76 To 0.95 Laserparam = 0.000091666 Case 0.96 To 1.15 Laserparam = 0.00011 Case 1.16 To 1.35 Laserparam = 0.000166666 Case 1.35 To 2 Laserparam = 0.000216666 End Select ' Set the value. "1.5" is compensating for lead/in out and positioning time. Result is in 1.0 hours oCustomProp.Value = Format((Laser * Laserparam) * 1.5, "0.0000") 'Show result MsgBox "Skjæretid for " & oSMDef.thickness.Value & " cm plate" & vbNewLine & "LaserLengde: " & Format(Laser, "0.00") & " cm" & vbNewLine & "LaserTid: " & Format((Laser * Laserparam) * 1.5, "0.0000") End Sub
