My add-in cannot be loaded
HideoYamada
Advisor Advisor
HideoYamada
One of my app user says that my add-in cannot be loaded.
The user send me the screen shot of Add-in Manager and it is strange.
"Loaded/Unloaded" checkbox is grayed out. I tried to reproduce this phenomenon but could not.
Does anyone know the condition to make this happen?
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Andrii_Humeniuk
Check out this post, maybe it will help you.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
HideoYamada
Hello Andrii,
Thank you for your reply. I'll check the parameters and then report the result.
Freeradical
 Hideo Yamada
Frederick_Law
Maybe user has no file opened.
List of options in .addin file:
  <!--LoadOnStartUp 1 LoadOnStartUp-->
  <LoadAutomatically>1</LoadAutomatically>
  <!--LoadBehavior  0:Start with Inventor -->
  <!--LoadBehavior  1:Start with part -->
  <!--LoadBehavior  2:Start with assembly -->
  <!--LoadBehavior  3:Start with presentation -->
  <!--LoadBehavior  4:Start with drawing -->
  <!--LoadBehavior 10:On Demand -->
  <LoadBehavior>4</LoadBehavior>
  <UserUnloadable>1</UserUnloadable>
  <Hidden>0</Hidden>
  <SupportedSoftwareVersionGreaterThan>15..</SupportedSoftwareVersionGreaterThan>
Michael.Navara
Your screenshot is not from Inventor and its command Tools->Options->Add-ins but from external application AddInMgr.exe located in install folder of Inventor (Like: "C:\Program Files\Autodesk\Inventor 2024\Bin\AddInMgr.exe").
HideoYamada
Thank you all!
In this case, my user had used the external "AddInMgr.exe" as @Michael.Navara said.
The user used Add-In manager in Inventor and the problem was resolved.
Freeradical
 Hideo Yamada
