Multiple view Representation and positional Representations
k14348
k14348
  I want to create 6 Nos. of view Representation and 6 Nos. of Positional Representation via Vba in Assembly file. Please find the attached file for reference. Can anybody help?
-karthikeyan M
k14348
Public Sub ViewRep()
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
MsgBox "An Assembly Mustbe Active"
End
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oCompDef As RepresentationsManager
Set oCompDef = oAsmDoc.ComponentDefinition.RepresentationsManager
Dim oDesignViewRep As DesignViewRepresentations
Set oDesignViewRep = oCompDef.DesignViewRepresentations.Add("Stub 100")
Set oDesignViewRep = oCompDef.DesignViewRepresentations.Add("Stub 200")
Set oDesignViewRep = oCompDef.DesignViewRepresentations.Add("Stub 300")
Set oDesignViewRep = oCompDef.DesignViewRepresentations.Add("Stub 400")
Set oDesignViewRep = oCompDef.DesignViewRepresentations.Add("Stub 500")
Set oDesignViewRep = oCompDef.DesignViewRepresentations.Add("Main Bom Stub 600")
End Sub
I tried something but it showing error. Can anybody help with this issue.
-karthikeyan M
bshbsh
my guess is this line
should be like this:
(without the last "s")
k14348
End
    oDesignViewRep = oCompDef.DesignViewRepresentation.Add("Stub 300")
    oDesignViewRep = oCompDef.DesignViewRepresentation.Add("Stub 400")
    oDesignViewRep = oCompDef.DesignViewRepresentation.Add("Stub 500")
    oDesignViewRep = oCompDef.DesignViewRepresentation.Add("Main Bom Stub 600")
End Sub
Not working 😞
bshbsh
it would have worked if you hadn't f* up the rest of the code...
End
End Sub
Not working 😞
k14348
Thank u its working
