Multiple Parts List
Multiple Parts List
Multiple Parts List
I need your help on this situation.
So i have a drawing with multiple components, and i want to have different parts list for differents components.
So the idea is to create views representation in the 3D model with all of the itens i want in each representation, for example one with only th cylinders, another only with spacers, another with bolt, etc...
And then i go to each part list and put a filter with that view representation, and i have the table that i want, the only problem i have is the "connection" between all the part list, because if i choose to open the itens (Image 1) to see the inormation i want, all the others parts list will open too!
And that is something that i don't want!
See the images below and try to follow my idea.
So there is any option i can choose to "break" this connection between all the parts list in the same drawing?
Thanks for the time and i'm sorry for my bad english! 😕
Ricardo
HermJan.Otterman
what you might want to use is the filter option in het edit parts list dialog.
you can set this to "Assembly view Representation"
I hope this helps
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
I already used that option.
But i still have a problem associate to the part list, i will try to explain if you can help me.
So i have a main plan:
0001 (IAM)
 -0002 (IAM)
    - 0006
    - 0007
    - 0008
 -0003 (IAM)
    - 0009
    - 0010
    - 0011
 -0004 (IAM)
    - 0012
    - 0013
    - 0014
 -0005 (IAM)
    - 0015
    - 0016
    - 0017
So this is my structure in my model, and i want to have a drawing in plan 0001 with a parts list and ballons for the main groups, 0002/0003/0004/0005.
Then i will create another sheet on drawing 0001 so I can add another parts list for each component, for example 0006/0009/0012/0015 are the same component, so i will creat a Assembly view Representation on 0001 to only show that itens, and then i select the part list put the filter and then open the itens so i can see the itens i select.
But when i do that the first part list i created on sheet 1, will open to, and the itens and baloon show now anoter itens, for example 006/0010/0013/0016 because this are the real components select, because IAM 0002/0003/0004/0005 doesn't have any real item, they are only IAM to agroup IPT with real components.
And what i want to know if it is possible to "break" that connection between part list.
Sorry for my bad english, and i hope you can understand my problem! Thanks for the time one more time!
