Multiple Mouse Select
ch_giacomo
ch_giacomo
Hi all, I've created this little rule that hide the lines or circles I want in a view with mouse selection.
But I can't set the selection to be multiple.
After the first selection the rule ends instead it should continue until the ESC key is pressed
Sorry but I'm new to ilogic
Here is the code:
Sub Main ()
	Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    Dim obj As DrawingCurveSegment
    obj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select")
    obj.Visible = False
End Sub
A.Acheson
Here is an article on how to integrate a while loop to achieve your goal.
From the article, adjust the pick SelectionFilterEnum as needed. Esc is used to exit the while loop
Dim comps As ObjectCollection
Dim comp As Object
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
	comp = ThisApplication.CommandManager.Pick(
		SelectionFilterEnum.kAssemblyOccurrenceFilter,
		"Select a component")
	' If nothing gets selected then we're done
	If IsNothing(comp) Then Exit While
	comps.Add(comp)
End While
' If there are selected components we can do something
For Each comp In comps
	comp.Delete()
Next
Regards
Alan
WCrihfield
Just another variation of the same using a Do...Loop.  There are several ways you could set this up.  You could use GoTo at the end to, then use Exit Sub when the DCS Is Nothing to escape the loop.
Sub Main ()
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim DCS As DrawingCurveSegment
	Do
	    DCS = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select")
		If IsNothing(DCS) Then Exit Do 'or Exit Sub
	    DCS.Visible = False
	Loop Until DCS Is Nothing
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
ch_giacomo
Thanks a lot for the help..
I'm at the basic level..
Here is the result:
While True
	If IsNothing(obj) Then Exit While
obj.Visible = False
End While
ch_giacomo
Grazie
Funziona alla grande @WCrihfield
