Multiple Form Instances
NachoShaw
Advisor Advisor
NachoShaw
Hey
How are people managing the control / prevention of multiple instances of a form when the ribbon button is clicked for their app? doesnt matter what i do, i can load 100's of them....
any great tips would be well received 🙂
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
dnguyennn
Anyone?
NachoShaw
Hey
If you're experiencing the same issue, it can be resolved in a few ways
you can
  • search for the process and show the form if it doesnt exist
  • make the form a dialog
I'll look at the code i use, its works just fine for me
Nacho
dnguyennn
I tried couple of them, but dialog won't work in my case. Note, I am using WindowWarapper for  "press space" to work.
WindowWrapper(m_inventorApplication.MainFrameHWND)
If Application.OpenForms().OfType(Of Form2).Any Then
  MessageBox.Show("Opened")
Else
  Dim f2 As New Form2
  f2.Text = "form2"
  f2.Show()
NachoShaw
Here is my code that is called as the button is clicked before anything else runs. ProcName is the name of the process
Dim ProcName As String = "MyProcessName"
Dim Proc() As Process = System.Diagnostics.Process.GetProcessesByName(ProcName)
If Proc.Length <> 0 Then
    Exit Sub
Nacho
dnguyennn
I can't make it working. It got as far as "Inventor.exe" and not able to find the Form, I think because it got wrap inside Inventor.
dnguyennn
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
Implements MyInterface
Private B_Form1 As Form1
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
m_inventorApplication = addInSiteObject.Application
m_applicationEvents = m_inventorApplication.ApplicationEvents
B_Form1 = New Form1
e_AppEvents = m_inventorApplication.FileUIEvents
End Sub
Private Sub Cmd1_OnExecute(ByVal Context As Inventor.NameValueMap) Handles Cmd1.OnExecute
    Try
        If B_Form1.IsDisposed = True Then
            B_Form1 = New Form1
            B_Form1.Activate()
            B_Form1.TopMost = True
            B_Form1.ShowInTaskbar = False
            B_Form1.Show(New WindowWrapper(m_inventorApplication.MainFrameHWND))
        If B_Form1.IsDisposed = False Then
            B_Form1.Activate()
    Catch ex As Exception
    End Try
End Sub
Well, I got it working by checking Disposed for Form1.Activate() ... and it works as I want to.
