Multibody and Ipart
Multibody and Ipart
halganabi
Message 1 of 10
Multibody and Ipart
halganabi
As u know we can't use the Multibody and ipart at the same time,
I have Multibodies part and have a parameter Length, so I want this parameter to be change and save as new and going to next in list,
For exampe i am saving the list of length in Excel or Text file,
Is there an ilogic rule or VBA code that :
read a value of "Length" from External Excel or any thing save it in parameter "Length " make Update save as new part and go to the next value of Length List
Replies (9)
Message 2 of 10
A.Acheson
Hi @halganabi
I'm not sure I follow. Saving as of the part is just creating another part but you mentioned you wanted iparts. Can you attach some images of what is changing? If you have a multibody part what you really need is an assembly/iassembly with the parts of different material within.
Regards
Alan
Message 3 of 10
Frederick_Law
Are you sure?
IV2023.4
Message 4 of 10
JelteDeJong
You could try something like this:
GoExcel.Open("C:\forum\filename.xlsx", "Sheet1")
For i = 2 To 10
	Dim length As String = GoExcel.CellValue("B" & i)
	Parameter("length") = length
	Dim newFileName = String.Format("C:\forum\MyPart_l{0}.ipt", length)
	ThisDoc.Document.SaveAs(newFileName, True)
Next
This rule assumes that you have an excel file "C:\forum\filename.xlsx" and a "Sheet1". the list of lengths starts on cell B2 and ends on cell B10
Jelte de Jong
Blog: hjalte.nl - github.com
Message 5 of 10
halganabi
the issue with this that you can not make components
Message 6 of 10
halganabi
Yes this works!
Thanks alot
Message 7 of 10
Frederick_Law
What do you mean by "can not make components"?
Probably I'm missing something.
I got 3 iParts, one with 2 bodies, the other 2 single body.
All in assembly:
Message 8 of 10
halganabi
yes but i don't want to use these in Assembly,
i want them to be generated as .ipt seperately so i can use each for idw
and i want to generate flat sheet for each, this require the body to be seperate file from the main part to be able to generate the flat sheet
Message 9 of 10
Frederick_Law
Please attach your iPart file.
I can make different sheet metal iPart and put them in drawing with flats.
Using IV2023.
Message 10 of 10
halganabi
your picture shown ipart with one solid only, my issue with multi solid and using ipart same time,
please find attached ipart file and check if it is possible to generate flat sheet for all cases and can be viewed at seperate items in idw
