Moving EndPoint/StartPoint of Centerline On Drawing
Tiffany_Hayden_
Tiffany_Hayden_
I've searched on the forums and I found back in 2005 that it wasn't possible to move the end points/start points. I'm curious if anything has changed. I know it's possible to move it manually.
Below I'm trying to move the start/end point of a centerline on a drawing. If anyone has any tips I'd appreciate it.
Public Sub MoveCenterlinePoints()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim oCenterline As Centerline
    Dim oWFeatureName As String
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oPt2D As Point2d
    Dim oCenterLinePt2D As Point2d
    Dim strPointPos As String
    For Each oCenterline In oSheet.Centerlines
        oWFeatureName = oCenterline.ModelWorkFeature.Name
            If oWFeatureName <> "XY Plane" And oWFeatureName <> "YZ Plane" And oWFeatureName <> "XZ Plane" Then
                If oCenterline.StartPoint.X / 2.54 = oCenterline.EndPoint.X / 2.54 Then
                    If oCenterline.StartPoint.Y / 2.54 > oCenterline.EndPoint.Y / 2.54 Then
                        strPointPos = "START"
                    Else
                        strPointPos = "END"
                Else
                    If oCenterline.StartPoint.X / 2.54 < oCenterline.EndPoint.X / 2.54 Then
                    Else
                        strPointPos = "END"
        If strPointPos = "START" Then
            Set oCenterLinePt2D = oCenterline.StartPoint
            Set oCenterLinePt2D = oTG.CreatePoint2d(100, 100)
        Else
            Set oCenterLinePt2D = oCenterline.EndPoint
    Next
End Sub
Tiffany Hayden
I am not sure if I understand correctly, buy You can try this code.
I added line for empty ModelWorkFeature (which may cause an error).
I aslso added reseting strPointPos property after changing centerline - it kept oldvalue.
But this code will change either startpoint or endpoint whit the same value, so I don't understand the point.
    Dim oSheet As Sheet
        If oCenterline.ModelWorkFeature Is Nothing Then
        oWFeatureName = ""
        Else
                    Else
                        strPointPos = "END"
                Else
                    Else
                        strPointPos = "END"
            'Set oCenterLinePt2D = oCenterline.StartPoint
            oCenterline.StartPoint = oCenterLinePt2D
        Else
            'Set oCenterLinePt2D = oCenterline.EndPoint
            oCenterline.EndPoint = oCenterLinePt2D
        strPointPos = ""
    Next
End Sub
Tiffany_Hayden_
Thank you @Anonymous. The point for me was to move the centerlines outside the margins of the view. Your code for
was the adjustment I needed. I wasn't pushing the new point into the end point. That was the trick! Thanks for your help!
Tiffany Hayden
