Moving a dimension to a position outside the arrow with ilogic
heliston_guimaraes
heliston_guimaraes
Hello everyone,
I created a dimension with ilogic. However, the dimension always appears centered, regardless of whether the arrows are inwards or outwards. How do I move a dimension to a position outside the arrow with ilogic?
I attach two images: one with the dimension centered and how the program creates it and the other with the dimension as I would like it to be created.
Thank you to anyone who can take the time to help.
Dim cotaCcomprimento_SF = genDims_SF.AddLinear("cotaCcomprimento_SF", VIEW01_SF.SheetPoint(DistCotaComprY + .1, + DistCotaComprX), diam1_SF, profcsliso_SF, DimensionTypeEnum.kVerticalDimensionType,)
cotaCcomprimento_SF.NativeEntity.TolerancePrecision = 2
cotaCcomprimento_SF.NativeEntity.Tolerance.SetToDeviation(+0.00, -0.03 * .1)
Michael.Navara
You can use something like this
Dim drwDim As Inventor.LinearGeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick dim")
Dim txtOrigin = drwDim.Text.Origin
txtOrigin.TranslateBy(drwDim.DimensionLine.Direction.AsVector())
drwDim.Text.Origin = txtOrigin
heliston_guimaraes
Thanks for the answer. It works, but it's not exactly what I need, as it will always require me to do manual editing, and if there are several quotas with the same problem, I will always need to check them one by one.
But I will save the code as it may be useful to me.
Thanks!
Michael.Navara
If you want more complex code to fix drawing, see this post.
It solves little bit different task, but you can combine it together.
m_baczewski
Hi @heliston_guimaraes
To start, you need to:
  1. Define the document.
  2. Find the dimension through the API and define it.
  3. Define the initial position of the dimension of interest.
  4. Define the new position of the dimension as a Point2D; in your case, you will need to add a value to the Y-coordinate.
  5. Assign the new position to the dimension.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oDimensions As drawingDimensions
oDimensions = oDoc.ActiveSheet.DrawingDimensions
Dim oDimension1 As LinearGeneralDimension
oDimension1 = oDimensions.Item(19)
Dim poczatkowePolozenieWymiaru1 As Point2d
poczatkowePolozenieWymiaru1 = oDimension1.Text.Origin
Dim nowePolozenieWymiaru1 As Point2d
nowePolozenieWymiaru1 = oTG.CreatePoint2d(poczatkowePolozenieWymiaru1.X - 1, poczatkowePolozenieWymiaru1.Y - 0.35)
oDimension1.Text.Origin = nowePolozenieWymiaru1
This is the method I've come up with, but there may be a better and faster way to solve this problem.
heliston_guimaraes
Thank you all. The comments were very useful and I was able to extract information to get the final result I wanted.
Below I leave the final code in which I obtained the result.
The last line of the schedule is what I needed.
cotaCcomprimento_SF.NativeEntity.Tolerance.SetToDeviation(+ 0.00, -0.03 * .1)
cotaCcomprimento_SF.NativeEntity.Text.Origin = ThisApplication.TransientGeometry.CreatePoint2d(cotaCcomprimento_SF.NativeEntity.Text.Origin.X, cotaCcomprimento_SF.NativeEntity.Text.Origin.Y+1)
