move / rotate parts and assembly and make a copy
GeorgK
Advisor Advisor
Message 1 of 10
GeorgK
Hello together,
how could I move / rotate a part or assemble and make a copy of it (like an array)?
Georg
Replies (9)
Message 2 of 10
Balaji_Ram
Hi Georg,
Does creating a circular pattern based on an occurrence help ?
This is similar to what is possible using the Assembly tab > Pattern > Pattern component in Inventor UI
http://adndevblog.typepad.com/manufacturing/2012/12/inventor-create-pattern-of-component-occurrences...
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 10
GeorgK
Hello Balaji,
it could help if the pattern explodes after the run.
Georg
Message 4 of 10
GeorgK
Hello Balaji,
I solved it with a RectangularPattern which I made independent and deleted it afterwards. But the constraints are lost. Is it possible to copy it with the constraints?
Georg
Message 5 of 10
adam.nagy
Autodesk Support
Autodesk Support
Hi Georg,
What constraints are you talking about? Are they between the components you are copying? - in case not just one being copied.
Best is to always check what happens in the UI.
If you do that, then you'll find that if multiple components are copied together and the constraints are between them then those constraints are kept, otherwise they are not.
Cheers,
Adam Nagy
Autodesk Platform Services
Message 6 of 10
GeorgK
Hello Adam,
the idea was to copy components with dependencies and insert them at new position.
Georg
Message 7 of 10
Balaji_Ram
Hi Georg,
In that case, i think you will need to compute the transformation matrix on your own and use it while adding a new occurrence.
or set the ComponentOccurrence.Transformation or SetTransformWithoutConstraints to transform it.
If that does not help, can you please share the model and explain what you are trying to move and rotate ?
Balaji
Balaji
Message 8 of 10
GeorgK
Hello Balaji,
Paste with all the constraints.
Or
Base point: where to copy the selected parts with constraints (like copy)
Insert point: where to insert the copied parts.
It's like in Autocad.
Georg
Message 9 of 10
Balaji_Ram
Hi Georg,
Sorry for the delay in getting back to you.
I do not find a way to do it other than executing the copy and paste commands after the occurrences have been selected.
This should also bring along any constraints that exist between the selected occurrences.
Here is a sample code :
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oAssyDef As AssemblyComponentDefinition
    Set oAssyDef = oDoc.ComponentDefinition
    Call oDoc.SelectSet.Clear
    Call oDoc.SelectSet.Select(oAssyDef.Occurrences.Item(1))
    Call oDoc.SelectSet.Select(oAssyDef.Occurrences.Item(6))
    Dim oCopyControlDef As ControlDefinition
    Set oCopyControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd")
    oCopyControlDef.Execute
    Dim oPasteControlDef As ControlDefinition
    Set oPasteControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd")
    oPasteControlDef.Execute
Balaji
Balaji
Message 10 of 10
GeorgK
Hello Balaji,
Thanks for your help. But I though that there may be a function like in Autocad.
Georg
