Move IPT Files with description string to assembly folder
Keith.Challinor3761
Keith.Challinor3761
In order to keep my assembly browser a little less busy I would like to move all parts that have a certain description string to an already existing assembly folder
Ralf_Krieg
Hello
It ignores patterns and all subassemblies, but maybe it's enough for your needs.
    Dim sFolderName As String = "Test" '<----------------------------Modify name of target folder
    Dim oAssDoc As AssemblyDocument = ThisDoc.Document
    Dim oBrowserPane As BrowserPane
    For Each oBrowserPane In oAssDoc.BrowserPanes
        If oBrowserPane.InternalName = "AmBrowserArrangement" Then Exit For
    Next
    If oBrowserPane Is Nothing Then Exit Sub
    Dim oTopNode As BrowserNode = oBrowserPane.TopNode
    Dim oBrowserFolder As BrowserFolder
    For Each oBrowserFolder In oTopNode.BrowserFolders
        If oBrowserFolder.Name = sFolderName Then Exit For
    Next
    If oBrowserFolder Is Nothing Then Exit Sub
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oAssDoc.ComponentDefinition.Occurrences
        Dim sDescription As String
        sDescription = oOcc.Definition.Document.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Description").Value
        If sDescription = "ToFolder" Then
            Dim oBrowserNode As BrowserNode = oBrowserPane.GetBrowserNodeFromObject(oOcc)
            If Not oBrowserNode Is Nothing Then
                Call oBrowserFolder.Add(oBrowserNode)
      Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
Keith.Challinor3761
Betreff
Many thanks for you post , unfortunately I don't seem to be able to format it correctly
[cid:image001.png@01D735CE.7BD23DB0]
Keith.Challinor3761
Many thanks to you both for your time
this works flawlessly
i know i have a lot to learn but this help spurs me on
thank you
