Move Face command generation with ILogic
Thomas.Long
Thomas.Long
I'm having difficulty finding the correct syntax necessary to generate a move face command. I was wondering if anyone could point me in the right direction. Everything else in my code works up until the "oMoveFace =" line.I can't find the syntax for the movefacefeatures portion, nor am I sure that create movefacedefinition will be the correction notation. Any help at all would be appreciated.
Thank you,
Thomas Long
'Declare Document Variables
	Dim oAsm As AssemblyDocument
	Dim oAsmCompDef As AssemblyComponentDefinition
	Dim oMoveFace As MoveFaceDefinition
	oMoveFace = oAsmCompDef.Features.MoveFaceFeatures.CreateMoveFaceDefinition(Face_End, kMoveFaceOperation)
	Call oMoveFace.SetDistanceExtent(Parameter("AngleEnd" & Instance) - Parameter("AngleStart" & Instance) - 120, kPositiveExtentDirection)
JarFu
Hi Thomas,
With Inventor 2011 and newer version, you can use below iLogic code to create the Move Face feature in assembly or part file.
Before running the rule, please select one face and one edge/ axis (as the direction), else oDoc.SelectSet(1) and oDoc.SelectSet(2) lines will raise error.
Dim oDoc
oDoc = ThisApplication.ActiveDocument
Dim oMoveFaces
oMoveFaces = oDoc.ComponentDefinition.Features.MoveFaceFeatures
Dim oFaceCol
oFaceCol = ThisApplication.TransientObjects.CreateFaceCollection
oFaceCol.Add (oDoc.SelectSet(1))
Dim oMFDef
oMFDef = oMoveFaces.CreateDefinition(oFaceCol)
oMFDef.SetDirectionAndDistanceMoveType( 1, oDoc.SelectSet(2))
Dim oMF
oMF = oMoveFaces.Add(oMFDef)
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
JarFu
Hi Thomas,
Dim oDoc
Dim oMoveFaces
Dim oFaceCol
Dim oMFDef
Dim oMF
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
Thomas.Long
Sorry for the late reply;
So I tried what you suggested and am getting an error.
Public member 'CreateDefintion' on type 'MoveFaceFeatures' not found.
The error occurs on the line
SyntaxEditor Code Snippet
oMFDef = oMoveFaces.CreateDefintion(Face_End)
I'm currently on Inventor 2015, so I'm guessing it might be a syntax difference? Here is a summary of my full Ilogic code for this function.
'Creates constraints for picked faces off of the base planes for the file
Function AngleSetup(SideDConstraint, DConstraint, SideAConstraint, AConstraint, Depth, SurfaceConstraint, Instance, Axis)
	'On Error Resume Next
	Dim Constrain As AssemblyConstraints
	Dim Face_Top As Face
	Dim Face_Web As Face
	Dim Face_End As Face
	Dim oDoc
	Dim oMF
	Dim oMFDef
	Dim oMoveFaces
	oAsm = ThisDoc.Document
	constrain = oAsm.ComponentDefinition.Constraints
	oMyParameter= oAsm.ComponentDefinition.Parameters.UserParameters
'Pick faces for constraining
	Face_Top = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities, "Select Left Flange")
	Face_Web = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities, "Select Right Flange")
	Face_End = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities, "Select end of angle")
'Constrain to XZ Plane
	If AConstraint = "Mate" Then Constrain.AddMateConstraint(Face_Web, SharedVariable("XZPlane"), SideAConstraint*2.54)
	If AConstraint = "Flush" Then Constrain.AddFlushConstraint(Face_Web, SharedVariable("XZPlane"), SideAConstraint*2.54)
'Constrain to YZ Plane
	If DConstraint = "Mate" Then Constrain.AddMateConstraint(Face_End, SharedVariable("YZPlane"), SideDConstraint*2.54)
	If DConstraint = "Flush" Then Constrain.AddFlushConstraint(Face_End, SharedVariable("YZPlane"), SideDConstraint*2.54)
'Constrain to XY Plane (Front View)
	If SurfaceConstraint = "Flush" Then Constrain.AddFlushConstraint(Face_Top, SharedVariable("XYPlane"), -Depth*2.54)
	If SurfaceConstraint = "Mate" Then Constrain.AddMateConstraint(Face_Top, SharedVariable("XYPlane"), -Depth*2.54)
	Length = Abs(Parameter("AngleEnd" & Instance) - Parameter("AngleStart" & Instance)) - 120
	oMFDef.SetDirectionAndDistanceMoveType(Length, Axis)
End Function
