Move camera to coord on drawing
CadUser46
CadUser46
I'm struggling to grasp this camera object.  I want to move the camera as if the user zoomed/panned to point on a sheet.
I have the XY values from the balloon I'm looking for but I cant do what I want.  The CameraPosX and Y are passed into this sub.  e.g X=9.5, Y=11.0
    Dim oDoc    As Inventor.DrawingDocument: Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet  As Sheet: Set oSheet = oDoc.Sheets(SheetName)
    'Actions
    oDoc.BrowserPanes("Model").Activate
    oSheet.Activate
    ' Get the active camera.
    Dim cam As Camera: Set cam = ThisApplication.ActiveView.Camera
    Dim tg As TransientGeometry: Set tg = ThisApplication.TransientGeometry
    ' Define the distance between the eye and target.
    Dim eyeDistance As Double: eyeDistance = 1
    ' Set the eye with a hard coded z value.
    cam.ViewOrientationType = kFrontViewOrientation
    cam.Eye = tg.CreatePoint(CameraPosX, CameraPosY, eyeDistance)
    cam.Target = tg.CreatePoint(CameraPosX, CameraPosY, 0)
    ' Define the up vector as positive z.
    cam.UpVector = tg.CreateUnitVector(0, 0, 0)
    'Dim cameraOr As ViewOrientationTypeEnum
    'cameraOr = kFrontViewOrientation
    'Call cam.SetExtents(CameraPosX + 10, CameraPosY + 10)
    ' Apply the current camera definition to the view.
    cam.ApplyWithoutTransition
Inventor 2010 Certified Professional
Currently using 2023 Pro
asiteur
I do not completely understand what you want to do, but there are some things in your code that don't work I think:
1) You set cam,Eye.Z=1. I have had only trouble when I changed the Z. I always maintain cam.Eye.Z=point(X,Y,cam.Eye.Z)
2) You set cam.UpVector to the Null vector. If I were the program I would have a hard time to interpret that. When I did this I couldn't find my drawing back on the screen. Use the default (0,1,0) or don't change at all if you don't want to rotate your sheet (likely).
3) You send SetExtents() , Target and Eye the same X and Y (almost), while there are very different. Target and Eye are for the location, SetExtents for the Zoom (how close you are to the object). I think it is unlikely that you want to zoom the same amount as the location you are...?
4) You use cam.ApplyWIthOutTransition, while from your description I read that you want a nice smooth pan/zoom movement. That is achieved with the normal cam.Apply.
I hope this helps!
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
CadUser46
Hi.  I tried to reply earlier but it crashed.
I got it to work although I didn't understand why.
1)  I don't understand what you mean.
2)  No I don't want to rotate the sheet, you are correct and I removed this.
3)  I don't understand the purpose of the Z value if it does not define the distance from the sheet.  It seems to have no effect on the code.
4)  Sorry for the confusion.  I just meant I want to zoom in.  The transition is not important.
The following code works for me although I still haven't fully grasped why.
    cam.Eye = tg.CreatePoint(CameraPosX, CameraPosY, 5)
    Call cam.SetExtents(CameraPosX, CameraPosY)
    Call oDoc.SelectSet.Clear
    Call oDoc.SelectSet.Select(MyBalloon)
adam.nagy
Autodesk Support
Autodesk Support
I think it would be useful for you to read through these couple of posts on this topic:
http://modthemachine.typepad.com/my_weblog/2013/09/working-with-cameras-part-1.html
http://modthemachine.typepad.com/my_weblog/2013/09/working-with-cameras-part-2.html
Because the Drawing View camera has a parallel view (and not perspective) therefore the distance between the target and eye does not change the field-of-view.
When calling SetExtents() you should pass in width and height of the field-of-view. You should probably check the extents of the object you want to zoom on and use the values from that.
Cheers,
Adam Nagy
Autodesk Platform Services
CadUser46
@adam.nagy Thanks.  Certainly explains the upvector better than the help file and explains why the distance between the target and eye makes no difference when in rectangular mode.
