Move already drawn dimensions
ysbaodnj
ysbaodnj
I would like to know how to position the dimensions drawn on the referenced drawing title block with i-logic.
I want to move the dimension position like the picture below,
Can i-logic take this dimension as an object and define the position?
- Dimensions drawn on the referenced title block.idw
- The position of the dimension to be moved with i-logic
I wish there was a way...
A.Acheson
Here is a vba sample of moving dimensions.
Moving the dimensions text looks like it is the key.
         oDimension.Text.Origin = oPosition
Regards
Alan
ysbaodnj
Thank you for answer! Problem solved 🙂
