Modifying Dimension Styles - Paralell First Above Landing Line - VBA
ccoomes
ccoomes
Does anyone know how to get to the parameter in VBA to that will modify the Parallel First Above Landing Lines as shown in the Picture Attached?
I know that you can modify the Style Etc through the Styles Manager, but this is not what I want to do.
Using VBA I have been able to modify and Change the Dimension Text, but I would like to Modify the Parallel First ABove Landing Line through a Macro as required.
Any help would be greatly appreciated.
Many Thanks.
philippe.leefsma
Try "DimensionStyle.LinearMultiLineTextOrientation" property:
Read-write property that gets and sets the position of multiple lines of text relative to the landing line in a linear dimension. Valid values are kAllAboveLandingLine and kFirstLineAboveLandingLine.
Hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
