Modify Tapinfo for Hole features
how can I modify a tapinfo in this command:
CreateTapInfo(True, "ISO Metric profile", "M8x1.25", "6H", False, "24mm")
to a tip angle instead of a flat one?
Within the help I don't find the right position to define  this feature. Are there any ideas about that issue?
dgreatice
im back, this my code. Before im use "AddDrilledByThroughAllExtent", now difference method for create Tapped Hole.
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oHoleCenters As Object
Set oHoleCenters = oDef.WorkPoints.Item("COG")
Dim oCenterPlacementDef As PointHolePlacementDefinition
Set oCenterPlacementDef = oDef.Features.HoleFeatures.CreatePointPlacementDefinition(oHoleCenters, oDef.WorkAxes.Item(1))
Dim oTappedHole As HoleTapInfo
Set oTappedHole = oDef.Features.HoleFeatures.CreateTapInfo(True, "ISO Metric Profile", "M8x1.25", "6H", False, "24mm")
'Call oDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oCenterPlacementDef, "10mm", kPositiveExtentDirection) 'old
Call oDef.Features.HoleFeatures.AddDrilledByDistanceExtent(oCenterPlacementDef, oTappedHole, "30mm", kPositiveExtentDirection, False, "118")
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
solomon_14
Thanks so much, been looking for this for a couple hours. There's not very much out on the internet for inventor VBA.
