modify Search from alldirectories to 1 defined directory
johan.degreef
Advisor Advisor
johan.degreef
I have this code which searches through my library (with subfolders) and places the part in the project in the folder where the assembly resides. Due to performance reason I would like to place all library parts in the same folder. "MyProject\PTN_LIBRARY"
I know nothing about coding, but would it be difficult for the guru's here to make this code only use 1 folder to place the ibrary  parts?
So looking for the custom library part is in subfolders
Placing and looking for previous identical parts should be in 1 folder
Imports System.IO
GetInput :
Six_Digit = InputBox("Enter 6 Digit number", "iLogic", 000000)
If Six_Digit = "" Then
	Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "C:\PTN_Part_Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
	If oFilename.Contains(Six_Digit) Then
		Dim oOptions As Inventor.NameValueMap
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
		sFilename = oFilename
		Exit For
Next
If sFilename = "" Then
	MessageBox.Show("No matching libary file found.", "iLogic")
	Return
iCounter = 0
'path from current file
oActiveAssemblyfolder = ThisDoc.Path & "\"
'path from current project file ( *.ipj)
oProjectfolder = _
ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath & "\"
Dim oProject_Filenames() As String
oProject_Filenames = System.IO.Directory.GetFiles(oProjectfolder, _
'count existing project files
For Each oFilename As String In oProject_Filenames
		iCounter = iCounter + 1
Next
'increment counter
'find the postion of the last backslash in the path
FNamePos = InStrRev(sFilename, "\", - 1)
'get the file name with the file extension
oName = Right(sFilename, Len(sFilename) - FNamePos)
'get the file name (without extension)
ShortName = Left(oName, Len(oName) - 4)
'get extension
oExt = Right(oName, 4)
If iCounter < 10 Then
	iCounter = "00" + CStr(iCounter)
ElseIf iCounter < 100 Then
	iCounter = "0" + CStr(iCounter)
Else
	iCounter = CStr(iCounter)
oNewName = ShortName & "_" & iCounter
oPathandName = oActiveAssemblyfolder & oNewName & oExt
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
'Dim oOcc As ComponentOccurrence
'oOcc = oAsmCompDef.Occurrences.Add( _
'oPathandName, oMatrix)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oPathandName)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
'oOcc.Grounded = False
'ThisDoc.Document.SelectSet.Select(oOcc)
'MessageBox.Show("New file created: " & vbLf & oPathandName, "iLogic")
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
WCrihfield
Just change the "SearchOption.AllDirectories" to "SearchOption.TopDirectoryOnly" at the end of your GetFiles call.
Wesley Crihfield
(Not an Autodesk Employee)
Michael.Navara
Here is modified part of your code for searching in top directory only and better performance
'Inputs from code above
Dim Six_Digit As String = "000000"
Dim oLibrary_Folder = "C:\PTN_Part_Library\"
'Search files
Dim searchPattern As String = String.Format("*{0}*.*", Six_Digit)
Dim oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, searchPattern, System.IO.SearchOption.TopDirectoryOnly)
If oFilenames.Length = 0 Then
	Return
Dim sFilename = oFilenames(0)'First element in array
'TEST
For Each fileName As String In oFilenames
	Logger.Debug(fileName)
Next
johan.degreef
Many thanks, but searching for the library part is in multiple directories, that is OK, so i tought it was the second part of the code that needs modifications?
Looking if the part already exists over all directories, should be changed to "project\PTN_LIBRARY" path
Copying the part to the project, should be changed from "oPathAndName" to "project\PTN_LIBRARY" path
iCounter = 0
oProjectfolder = _
Next
'increment counter
'get extension
Else
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
