Modifications to rule to run from Visual Studio rather than just from Inventor
Ethibaudeau
Message 1 of 9
Ethibaudeau
Currently, I have been editing rules in Notepad++, and running them from within Inventor (iLogic pane, or adding a button on ribbon). But I would like to start using Visual Studio 2019 to run/debug code while still maintaining the ability to run these rules from Inventor.
This code works fine when running from Inventor:
Public Class HelperClass
    'Helper
End Class
Class ThisRule
    Dim oDocument As Document 'Declaring variable here so it can be
    'used across the subs/functions without having to pass it each time
    Sub Main
        'Code here
    End Sub
    Function DoStuff()
    End Function
End Class
To run the above code in Visual Studio, I know I need a few differences. I have the Visual Studio project referencing "Autodesk.Inventor.Interop" and I know I need to create an object for the Inventor application:
Imports Inventor
    'Helper
End Class
Class ThisRule
    Dim ThisApplication As Inventor.Application
    Sub Main()
        ThisApplication = GetObject(, "Inventor.Application")
    End Sub
    Function DoStuff()
    End Function
End Class
But the code above results in an error in VS2019 "No accessible 'Main' method with an appropriate signature was found". I tried various iterations of making "Main" and "ThisRule" either "Public", or "Shared", but admittedly I don't know the best way to use those keywords in practice.
Replies (8)
Message 2 of 9
WCrihfield
Hi @Ethibaudeau.  I see that you figured out the ThisApplication term, and how to replicate it in vb.net.  Here is a couple links to some other related things you may want to replicate.
This link shows several terms (pre-defined object variables) that only exist within an iLogic rule, because they are created for us behind the scenes for us by the iLogic ApplicationAddIn.
Rule Objects
Then this link just clues you in to some settings that are set for us automatically behind the scenes in the iLogic rule editor.
Advanced iLogic Techniques Reference
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 9
Ethibaudeau
I appreciate the reply. I believe I have mostly avoided iLogic in the rules I've created so far (sticking to just using the Inventor API), so I don't think there's much to convert over except some Logger and MessageBox statements as well as more explicitly stating the namespace for some enums.
As far as my code that is not working, it looks like I've followed the general idea in your second link under "Additional Statements" for how to set up "Main()" and "Class ThisRule", so I'm still stuck on where I went wrong and the error that "Main" is not accessible. Changing to "Shared Sub Main" or "Public Sub Main" does not change the error.
Message 4 of 9
Frederick_Law
You might need to follow addin instruction:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-52422162-1784-4E8F-B495-CDB7BE9987AB
VBA and iLogic removed lots of setup codes so they're very easy to learn.
Addin on the other hand require a lot more.
Also look at this:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/29mPk2V7aweIo6eLckSF1k.html#:~....
Message 5 of 9
Ethibaudeau
Thanks for those - though I wasn't able to get much from them. Those examples are more complicated than what I'm looking for. Maybe I'm being stubborn, but I'm not looking to create a add-in.
I just want rules I can run in Inventor and be able to edit/run them in Visual Studio.
Message 6 of 9
Frederick_Law
You can't.
You can keep hitting your head on the wall until the wall go away or find your way around the wall.
You're trying to put diesel in gasoline car.
You can get it to work if you swap the fuel system, ignition system and engine.
iLogic rules run inside IV.
VS run outside IV and need extra code to connect to IV.
iLogic don't have any debugging options.
VBA does.
Another way to debug iLogic is use Logger to put information in the log.
I use Logger.Info
Message 7 of 9
Ethibaudeau
I think that's totally fair that some extra code is needed to run from VS.
I'm just missing what code that is. In my initial post I made an attempt at simple template that has some of those changes to make the script run from VS.
Unless... are you saying that you can not run scripts from outside of Inventor - and that they must be compiled add-ins?
Message 8 of 9
Frederick_Law
I've setup VS Community to compile and run with full debug with IV addin.
There are a few things needed to setup to do that.
On one of the link I attached use simpler code than full addin.  I didn't went through that and test.
I think it's part of the "Check out the self-paced guide “My First Plug-in”" at the top of the forum.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/check-out-the-self-paced-guide-my-fi...
I started in VBA, skipped iLogic (because it doesn't has all the events), get to addin and trying iLogic again.
Lot's of reading.
Message 9 of 9
JelteDeJong
You might want to have a look at my project on Github. It was created to write and debug iLogic rules from Visual Studio. In the blog post "Writing and debugging iLogic rules" you will find some more info.
Jelte de Jong
Blog: hjalte.nl - github.com
