Models selection in Browser tree-Drawing Mode
karram
karram
Hello Sanjay,
                 In Inventor Drawing Mode how to select the models in Browser tree using VBA, I think using selectset is not possible in my knowledge. Is there any other way to execute the selection . Here I attached the screen shot for more details. Please refer . Hopefully I've explained our needs well enough, if not let me know and I'll try to clarify
adam.nagy
Autodesk Support
Autodesk Support
Is the issue with selecting multiple nodes?
I don't have a solution for that. A single node you can easily select using BrowserNode.DoSelect
Why do you want to select those node? Are you just trying to select the drawing curves that belong to them?
In that case you can get those back from the drawingview and then select them:
http://adndevblog.typepad.com/manufacturing/2012/05/adding-drawingcurve-to-selectionset.html
Cheers,
Adam Nagy
Autodesk Platform Services
