ModelParameterObject in API
breinkemeyer
breinkemeyer
I'm doing some C# to some model customization.  In the ModelParameters Object there is supposed to be an "Item" property as per the documentation.  Using VS2017 and have added the Inventor reference.  as a workaround I'm looping through, but that seems odd,.  code is below.
// start with the pipe file
System.IO.File.Copy(sTemplatePath + "Pipe.ipt", ProjectPath + "Pipe_" + sFileName + ".ipt");
Ready = false;
cSE.oIPartDoc = (PartDocument)cSE.oIDocs.Open(ProjectPath + "Pipe_" + sFileName + ".ipt");
if (!Ready)
Thread.Sleep(250);
//now update the parameters
cSE.oIPartCompDef = cSE.oIPartDoc.ComponentDefinition;
cSE.oIModelParameters = cSE.oIPartDoc.ComponentDefinition.Parameters.ModelParameters;
foreach (ModelParameter modelParameter in cSE.oIModelParameters)
string name = modelParameter.Name;
switch (name)
case "Length":
modelParameter.Value = dScrewLength * cSE.IV;
break;
case "OutsideDia":
modelParameter.Value = dPipeOD * cSE.IV;
break;
case "InsideDia":
modelParameter.Value = dPipeID * cSE.IV;
break;
cSE.oIPartDoc.Update();
YuhanZhang
In C#, you can also get a ModelParameter using its name as index, but not like in VB.net it does not use it like ModelParameters.Item("Length"), it just uses below format:
modelParam = ModelParameters.["Length"];
This also applies to other cases if you want to get an item from a collection object in C#. Hope this clears.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
breinkemeyer
Thank you sir!  works perfect.
