Model tree contrast
Model tree contrast
Model tree contrast
I have difficulty with inventor on my laptop, there's not enough contrast so when I edit a part within an assembly, I am unable to find it in the model tree and I don't think there's an option to change the colors.
JelteDeJong
You could make a iLogic rule that select the part you are editing. Then it gets highlighted with more contrast. but maby its inconvenient to run the rule each time.
try puting this rule in an external ilogic rule.
Dim aDoc as AssemblyDocument = ThisApplication.activedocument
Dim occ as ComponentOccurrence = aDoc.ComponentDefinition.ActiveOccurrence
If (occ IsNot Nothing) Then
	aDoc.SelectSet.Select(occ)
Jelte de Jong
Blog: hjalte.nl - github.com
