Missing Trailing Zeros in Title Block display
tim.gray2S8N5
tim.gray2S8N5
Our new Drawing Title Block has a dynamic tolerance table, the iLogic form allows selection of 3 different tolerance levels (Standard, Medium, Fine), some iLogic code then adjusts the tolerance value for each tolerance band in line with the selected level.
Problem is that any value above 0.x is rounded up and it loses it's trailing zeros.
    (Two empty rows are to be deleted)
The relating iLogic code is below:
     (The code above the IF statements was found online and modified to suit)
Any ideas to resolve this?
JhoelForshav
Hi @tim.gray2S8N5
You could try using properties of type Text instead of Number. Just put quotation marks around the value to make it a string instead of a double. Like this:
iProperties.Value("Custom", "TOL2") = "1.0"
tim.gray2S8N5
Well, that was an easy solve - thanks.
