mirroring an iPart in iAssembly
How do i Mirror a  iPart in iAssembly, or how could i generate mirrored factory components for an iPart. ?
salariua
This is Inventor Customization forum, in general, we post here programming questions. For normal Inventor questions, I would use Inventor Forum General.
Here is how one can create iAssemblies with mirror iParts. One option is to use mirror on the entire body with remove original.
If it's via API you need this then ignore me and my post.
Screencast servers are down but the end result will be here once they come back up again.
see if this animation works instead.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
I didn't know about this, thanks for your information
@salariua wrote:
"This is Inventor Customization forum, in general, we post here programming questions. For normal Inventor questions, I would use Inventor Forum General."
you saved my life.. Thanks..!
