Mirrored Part But Link To Original Part
isocam
isocam
Can anybody help?
I have the following VBA macro that mirrors a part (ipt)
Public Function CreateMirrorPart()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCol As ObjectCollection
    Set oCol = ThisApplication.TransientObjects.CreateObjectCollection
    oCol.Add oDoc.ComponentDefinition.SurfaceBodies(1)
    Dim oPlane As WorkPlane
    Set oPlane = oDoc.ComponentDefinition.WorkPlanes(1)
    Dim oMirror As MirrorFeature
    Set oMirror = oDoc.ComponentDefinition.Features.MirrorFeatures.Add(oCol, oPlane, True, kOptimizedCompute)
    oMirror.NewBodyOperation = True
End Function
I want to modify the VBA macro so that the mirrored part automatically updates if the original part is modified.
Can anybody update the above macro to allow me to do that?
Many thanks in advance!!!!
Darren
k14348
    Hope below code solve your issue.
Option Explicit
    'Create Mirror Part and remove orginal part.
    Set oMirror = oDoc.ComponentDefinition.Features.MirrorFeatures.Add(oCol, oPlane, False, kOptimizedCompute)
End Function
-Karth
WCrihfield
I believe in your "Set oMirror = " line, the "Add" portion should be ".AddByDefinition(oMirrorFeatureDefinition)"
They you would, of course, have to define the oMirrorFeatureDefinition, before that line.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
@isocam
I also think that if you want the original to always be the same as the mirrored one, you should have this code name the feature.  Then earlier in the code, check to see if it already exists, if so, either delete & recreate it, or edit its definition.
Wesley Crihfield
