Mirror multible solids with ilogic
ejaL9K8H
Message 1 of 24
ejaL9K8H
Hi
I would like to mirror multible solids (166) with one miror feature.
I have a code, which is working with one solid at the time, but what do I have to change or add to mirror more solids at once?
I dont want 166 new mirror features added to model, but only one.
Sub Main()
'Create Mirror Part and remove orginal part.
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oCol As ObjectCollection
    oCol = ThisApplication.TransientObjects.CreateObjectCollection
    oCol.Add(oDoc.ComponentDefinition.SurfaceBodies(1)) ' What do i have to write in this line, to mark multible solids?
    Dim oPlane As WorkPlane
    oPlane = oDoc.ComponentDefinition.WorkPlanes(3)
    Dim oMirror As MirrorFeature
    oMirror = oDoc.ComponentDefinition.Features.MirrorFeatures.Add(oCol, oPlane, True, kOptimizedCompute)
    oMirror.NewBodyOperation = True
End Sub
Thanks in Advance.
Replies (23)
Message 21 of 24
ejaL9K8H
Sorry I am a bit new to this coding. Im now sure what you mean about a different 'PatternComputeTypeEnum' variation ?
Message 22 of 24
WCrihfield
Sorry, I should have provided more information about it when I posted.  When creating a new MirrorFeature using the MirrorFeatures method called 'AddByDefinition', you first have to create a MirrorFeatureDefinition object, using the MirrorFeatures.CreateDefinition method.  The last optional input variable being requested by the CreateDefinition method is called "ComputeType", and it is expecting a value from the PatternComputeTypeEnum Enumerator.  I was just wandering if changing what you specify for that PatternComputeTypeEnum value would maybe change the outcome of your code, or somehow make it work, where it has been failing previously.  Just a thought.
Wesley Crihfield
(Not an Autodesk Employee)
Message 23 of 24
Hello, I'm new to this forum but using Inventor for a few years now. Recently we have upgraded to Inventor 2021 and I have encountered a strange situation. In Inventor drawing I cannot get a dimension between a face and a sharp edge in a flat pattern. I have tried direct dimension, with intersection between two lines and via a sketch and point with no results.
Message 24 of 24
ejaL9K8H
Thanks for all your advices!
I succeeded in making a code, where I firstly combine all solid bodies into one solid, whereafter it is possible to mirror this single solid. Here is the code I am using, if anyone is interessed:
'Combine and Mirror
Sub Main()
' Check the Document type
If (oDoc.DocumentType = kPartDocumentObject) Then
	Try
		'delete named feature if it exists
		oDoc.ComponentDefinition.features.CombineFeatures.item("My_Combine").delete
	Catch
	End Try
	'get the first body to use in as the base body in the combine
	Dim oBody As SurfaceBody
	Try
		oBody = oDoc.ComponentDefinition.SurfaceBodies.Item(1)
	Catch
		MessageBox.Show("Could not find the base body", "ilogic")
		Return ' can't get body so exit rule
	End Try
	'create a collection
	Dim oColl As ObjectCollection
    oColl = ThisApplication.TransientObjects.CreateObjectCollection
	'get the solid body count
	oCount = oDoc.ComponentDefinition.SurfaceBodies.Count
	'add the rest of the bodies to the collection
	For  i = 2 To oCount
		oColl.Add(oDoc.ComponentDefinition.SurfaceBodies.Item(i))
	Next
	'create the combine feature
	oCombine = oDoc.ComponentDefinition.features.CombineFeatures.Add _
	(oBody, oColl, PartFeatureOperationEnum.kJoinOperation, True)
	'rename the feature
	oCombine.name = "My_Combine"
'Mirror Solid:
End Sub
