Minimum Flange Height iLogic Rule
Developing an external rule that is triggered on 'Part Geometry Change' to ensure that any sheet metal flange heights which are less than the minimum are flagged up to the user.
There's a couple of things not quite perfect with it. Any tips on solving these would be much appreciated:
  1. After setting a new flange height (through the inputbox) the parameter has a huge trail of zeros (i.e 12.00000000 mm), I would like this to just be 12 mm, 12.5 mm etc
  2. I would love to include a color change to highlight the feature but I get some funny looking results (see attached images) as if the model geometry hasn't updated properly when the message box is presented.
  3. If I try to delete a flange that's too small, the rule is triggered and detects this flange, even though I just tried to delete it (guessing that solving point 2 will also solve this one)
See code below, or I've attached a sample part file.
Sub Main ()
' Get active document
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
' Make sure the active document is a sheet metal document.
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
   MsgBox ("A sheet metal document must be open.")
    Exit Sub
' Get component definition of part
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Get the referenced document feature collection
Dim oFlangesFeatures As PartFeatures
oFlangeFeatures = oCompDef.Features.FlangeFeatures
' Get thickness of part
Dim thickParam As Double
thickParam = Double.Parse(oCompDef.Thickness.Value * 10)
'MsgBox(thickParam)
' Set Min Flange rules
If thickParam = 1
    MinFlange = 6
ElseIf thickParam = 1.5
    MinFlange = 8.5
ElseIf thickParam = 2
    MinFlange = 9
ElseIf thickParam = 3
    MinFlange = 12
ElseIf thickParam = 4
    MinFlange = 17.5
ElseIf thickParam = 5
    MinFlange = 31
ElseIf thickParam = 6
    MinFlange = 33.5
ElseIf thickParam = 8
    MinFlange = 34
Dim oFlange As FlangeFeature
For Each oFlange In oFlangeFeatures
oFlangeHeight = oFlange.Definition.HeightExtent.Distance.Value * 10
If oFlangeHeight < MinFlange
    Feature.Color(oFlange.Name) = "Red"
    myparam = InputBox(oFlange.Name & " is less than the minimum required." & vbLf & "The minimum distance required is " & MinFlange & vbLf & vbLf & "Enter new flange height.", "Flange Error", MinFlange)
    Feature.Color(oFlange.Name) = "As Body"
    oFlange.Definition.HeightExtent.Distance.Value = myparam/10
    RuleParametersOutput()
    InventorVb.DocumentUpdate()
Next
End Sub
Ooops forgot to attach images
JaneFan
Hey @Anonymous,
Thank you for your reporting.
For issue 1, please try to use set expression of the Distance instead.
oFlange.Definition.HeightExtent.Distance.expression  = (myparam).ToString + "mm"
Issue 2 is tracked in our internal system.
For issue 3, deleting a feature definitely changes the part geometry so that the rule will be triggered accordingly. How about making the Min Flange rule being triggered by Model Parameter Change?
Jane Fan
Inventor/Fusion QA Engineer
Hi @JaneFan
Thank you for your response and for solving my first problem.
I have tried the event trigger 'Model Parameter Change', unfortunately this will not work for me, as I need the rule to run when a new flange is created.
I am happy for the rule to run on part geometry change, but only if there a way to force Inventor to execute the delete command before the rule reaches the For loop?
b_sharanraj
Hi @Anonymous
Please find the attachment 🙂
Regards
B.Sharan Raj
Thank you @b_sharanraj
You have solved issue number 2 🙂
Although, I do not want a loop, as I would like the user to be able to enter a value that is smaller than MinFlange if they wish so and for it to be accepted.
I have edited your code as below, it almost perfect but I still have issue number 3:
Sub Main ()
    Exit Sub
'MsgBox(thickParam)
If thickParam = 1
    MinFlange = 6
    MinFlange = 8.5
    MinFlange = 9
    MinFlange = 12
    MinFlange = 17.5
    MinFlange = 31
    MinFlange = 33.5
    MinFlange = 34
myparam = oFlangeHeight
    oFlange.Definition.HeightExtent.Distance.expression = myparam
    'Do Until myparam >= MinFlange
    ThisApplication.ActiveView.Update()
    'MessageBox.Show(myparam, "Title")
    myparam = InputBox(oFlange.Name & " height of " & oFlangeHeight & " mm is less than the minimum required." & vbLf & vbLf & "The minimum distance required is " & MinFlange & vbLf & vbLf & "Enter new flange height.", "Flange Error", MinFlange)
    'Loop
Next
End Sub
b_sharanraj
I have been tried and get got the code to delete the existing Flange if it's less MinFlange.
But i can see that you are planning to use this as an Sheetmetal Template so that a new flange feature will be taken care by that code.
Inventor crashes when I'm checking for a new flange feature.
Add the below one at the end of the existing code
If myparam < MinFlange then
ThisApplication.ActiveDocument.ComponentDefinition.Features.FlangeFeatures.Item(oFlange.Name).delete
Regards
B.Sharan Raj
