Method add of object ComponentOccurrences failed
Hi Everyone,
I have an excell spreadshhet and a modified copy of the add occurence sample from the help file. I tried to test the code by changing the parameters in the excell spreadsheet and the code runs OK first (maybe second time), but fails afterwards with the following error -2147467259 (80004005): Method add of object ComponentOccurrences failed.
Can anybody tell me what it is wrong with it? Thanks.:
Public Sub AddFixedIdler()
Dim oOcc As ComponentOccurrence
Dim myobject As Inventor.AssemblyDocument
Dim FileName As String
Dim Directory As String
 'Set a reference to the existing open document
Set myobject = ThisApplication.ActiveDocument
'update and save the assembly
    'suppress apllication notifications
        ThisApplication.SilentOperation = True
            myobject.Update
            myobject.Save
     'unsuppress apllication notifications
        ThisApplication.SilentOperation = False
File_Name = myobject.FullFileName
Directory = Left(File_Name, InStrRev(File_Name, "\") - 1)
    ' Set a reference to the assembly component definintion.
    ' This assumes an assembly document is open.
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
   ' Obtain the Parameters collection
    Dim oParams As Parameters
    Set oParams = myobject.ComponentDefinition.Parameters
    INo = oParams.Item("INo").Value
    FINo = oParams.Item("FINo").Value
    Idis = oParams.Item("IS").Value
    ImRTtSdis = oParams.Item("ImRTtSdis").Value
    Shim = oParams.Item("Shim").Value
    FIdlerType = oParams.Item("FIdlerType").Value
'select idler (Ind STD or CST STD)
Dim Idler As String
If FIdlerType = 0 Then
    Idler = Directory + "\30006.iam"
Else
    Idler = Directory + "\30027.iam"
 'Delete existing fix idlers
 For Each oOcc1 In myobject.ComponentDefinition.Occurrences
    If (InStr(oOcc1.Name, "30006") <> 0) Or (InStr(oOcc1.Name, "30027") <> 0) Then
        oOcc1.Delete
Next
    ' Set a reference to the transient geometry object.
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    ' Create a matrix.  A new matrix is initialized with an identity matrix.
    Dim oMatrix As Matrix
    Set oMatrix = oTG.CreateMatrix
    ' Set the rotation of the matrix for a 90 degree rotation about the Y axis.
    Call oMatrix.SetToRotation(3.14159265358979 / 2, _
                            oTG.CreateVector(0, 1, 0), oTG.CreatePoint(0, 0, 0))
    ' Set the translation portion of the matrix so the part will be repositioned
    Dim yLocation As Single
    yLocation = ImRTtSdis + Shim
    Dim xLocation As Single
    For i = 0 To INo - 1
    xLocation = (2 * i - INo + 1) * Idis / 2
    Call oMatrix.SetTranslation(oTG.CreateVector(xLocation, yLocation, 0))
    ' Add the occurrence.
    Set oOcc = oAsmCompDef.Occurrences.Add(Idler, oMatrix)
    'set occurence LOD to Custom
    oOcc.SetLevelOfDetailRepresentation ("Custom")
    Next i
            myobject.Update
            myobject.Save
End Sub
MegaJerk
Can you post a portion of your code that you're having problems with?
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
dano0310
Hi
I had a quick skim and can't seem to find where "my_path" is defined.
Dan
adam.nagy
Autodesk Support
Autodesk Support
Happy New Year.
Is this question still waiting for an answer?
According to its logged date under the title "01-15-2012" it's a year old now  :-s - is that correct?
Cheers,
Adam Nagy
Autodesk Platform Services
