measure number between extension line
jostroopers
jostroopers
I have placed a part on a drawing.
I have added dimensions.
This model can occur in different lengths.
If I change the model in length, my model will be neatly adjusted in the drawing.
Only the number of the dimensions is no longer in the middle between the extension lines.
How can I make sure that the number is neatly in the middle between the extension lines after I have changed the length of the model.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
Sergio.D.Suárez
Hi, I think you should look for a way to identify the dimensions. In this example of ilogic, you will center all the dimensions of the active sheet
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet= oDoc.ActiveSheet
For Each oDrawingDim As DrawingDimension In oSheet.DrawingDimensions
    If TypeOf oDrawingDim Is LinearGeneralDimension Or _
       TypeOf oDrawingDim Is AngularGeneralDimension Then
        Call oDrawingDim.CenterText
Next
You can center a specific dimension if you identify it through the item, as in this example
Dim oSheet As Sheet = oDoc.ActiveSheet
oSheet.DrawingDimensions(1).CenterText
 Maybe you could put an event to the drawing file so that the rule runs automatically. For example, before any change of drawing view or before saving the drawing file.
I hope this helps with your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
jostroopers
Hi Sergio
Thanks for the quick response.
The first code works for me.
I placed it to the After Save Document event trigger.
Thanks a lot.
Mvg Jos
CCarreiras
Hi!
I tried the code but ia have an issue... i have to run it twice to center the dimensions.
Fisrt time i run the code, nothing happens.
It's supposed to work like that?
inv2020.1
CCarreiras
Sergio.D.Suárez
The code is not supposed to do that, try this code
If the code does the same as above, try the following.
    If oDrawingDim.Type = 117474560 Or oDrawingDim.Type = 117474816 Then
Next
 Sometimes inventor performs the operations but the changes are not displayed correctly, a trick that works for me is to turn on and off so that they update themselves.
		oDrawingDim.HideValue = True
		oDrawingDim.HideValue = False
Next
I hope this helps. regards
Mechanical Designer
CCarreiras
Hi!
After i add your fixes, it star to working well.
Then... i deleted the fixes (back to the original code again).... and now, it works well!!
Therefore...... your original code should work well.
Sorry,  i don't know what happens before.
CCarreiras
jostroopers
After some tests with the length of my model, the dimensions were not placed in the middle. I also used the other codes but then nothing changed. I now have an event trigger after saving the document and have placed the rule in it twice. Now it works.
Mvg Jos
