measure minimum distance
michielXWZ7U
michielXWZ7U
Hi there!
I get a lot of sheet metal parts send to me as .step file. Now i manually measure the minimal thickness and add it to the bom list.
Is there an option that enables me to create a variable that scans the Part i am working with, and fetches the mimimum distance within the part, which always should display the material thickness.
With kind regards,
Michiel
vpeuvion
Maybe something like this with iLogic.
Dim Thickness As Double  = MinOfMany(Measure.ExtentsLength, Measure.ExtentsWidth, Measure.ExtentsHeight)
MessageBox.Show(Thickness)
Hoping it helps.
Vincent.
michielXWZ7U
thanks for youre reply, unfurtunatly it is not sufficient for my question. When i sketch for example a tube of 10x20x2 and 1000 mm long, It gives me only the shortest outter size. In the case of the tube in the example this will be 20.
With kind regards,
Michiel
vpeuvion
You can try that for a tube.
Sub main()
	'Measures the minimum distance between plane faces that have a parallel normal
	Dim oPart As PartDocument = ThisApplication.ActiveDocument
	Dim oPartCompDef As PartComponentDefinition = oPart.ComponentDefinition
	Dim oMeasure As Double = 12 'Maximum thickness
		For Each oFace As Face In oPartCompDef.SurfaceBodies(1).Faces
			If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
				Dim params(3) As Double
				Dim Normals(2) As Double
				oFace.Evaluator.GetNormal(params, Normals)
				Dim oUnitNormal As UnitVector = ThisApplication.TransientGeometry.CreateUnitVector(Normals(0),Normals(1),Normals(2))
				For Each oFace2 As Face In oPartCompDef.SurfaceBodies(1).Faces
					If oFace2.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
						Dim params2(3) As Double
						Dim Normals2(2) As Double
						oFace2.Evaluator.GetNormal(params2, Normals2)
						Dim oUnitNormal2 As UnitVector = ThisApplication.TransientGeometry.CreateUnitVector(Normals2(0),Normals2(1),Normals2(2))
						If oUnitNormal.IsParallelTo(oUnitNormal2) Then
						oMeasure2 = ThisApplication.MeasureTools.GetMinimumDistance(oFace, oFace2.PointOnFace) * 10
							If oMeasure2 > 0 And oMeasure2 < oMeasure Then oMeasure = oMeasure2
				Next
		Next
	MessageBox.Show(Round(oMeasure))
End Sub
There may be simpler. To develop.
 Vincent.
