Measure between Origin and a component plane
6.Day.Old.Filet-O-Fish
I have an assembly and I need to measure the distance between its YZ plane and a plane within a component.
I'm having issues with a bit of code. It is not throwing any errors but is getting the wrong solution. It always equals 0mm even though the actual measurement is several meters. What am I doing wrong?
' Get the assembly document
Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
' Get the assembly YZ plane
Dim asmYZPlane As WorkPlane = asmDoc.ComponentDefinition.WorkPlanes.Item("YZ Plane")
' Get the component occurrence
Dim compOcc As ComponentOccurrence = asmDoc.ComponentDefinition.Occurrences.ItemByName("Component1")
' Get the work plane from the component
Dim planeB As WorkPlane = compOcc.Definition.WorkPlanes.Item("Component1_Plane")
' Use MeasureTools to get the minimum distance
Dim measureTools As MeasureTools = ThisApplication.MeasureTools
Dim distance As Double = measureTools.GetMinimumDistance(asmYZPlane.Plane, planeB.Plane)
' Convert distance from cm to mm (if needed)
distance = distance * 10
' Output the result
MessageBox.Show("Distance between YZ Plane and PADEYE_REAR of PADEYE: " & distance & " mm")
WCrihfield
Looks like you are just missing the step where you need to get the 'proxy' of that component's WorkPlane that is in the context of the assembly, instead of in the context of that component's definition.  See altered example below.  Then, use the faces, or WorkPlane objects directly, instead of their 'planes'.
'get the 'proxy' of that component's WorkPlane that is in the context of the assembly
'first create the variable for the proxy
Dim planeBProxy As WorkPlaneProxy = Nothing
'now use a method of the component to get the proxy, supplying both variables
'this sets the value of the proxy variable
compOcc.CreateGeometryProxy(planeB, planeBProxy)
'now use that proxy object for the measurement, instead of the original
Dim distance As Double = measureTools.GetMinimumDistance(asmYZPlane, planeBProxy)
' Output the result
Wesley Crihfield
(Not an Autodesk Employee)
TY kind sir! So fast, prolly cause it was obvious!
I gotta learn that 'proxy' stuff. Still doesn't make sense to me but not the first time it's hung me up.
