Material in Sheet Metal Rule
w.pepping
w.pepping
In a sheet metal part I read the material by this code:
oSheetMetalCompDef = CType(oDoc, Inventor.PartDocument).ComponentDefinition
Dim strMaterial as String = oSheetMetalCompDef.Material.Name
In this part i get 'Generic', but in the iProperties it is 'S335J2G3'. See the attached image. How can I read this material and wich material (Generic or S225J2G3) is used for this part by Inventor?
Get control of your sheet metal files.
Download the app from matprop.com
adam.nagy
Autodesk Support
Autodesk Support
As I was playing around with it when I changed the material in the rule then it did not get propagated to the Ribbon straight away.
Once I opened the Materials dialog it showed the correct value - so I'm quite sure that these values should be the same everywhere.
Also PartComponentDefinition.Material is now hidden so could use Document.ActiveMaterial instead:
Sub ShowMaterialName()
  Dim d As PartDocument
  Set d = ThisApplication.ActiveDocument
  Dim cd As SheetMetalComponentDefinition
  Set cd = d.ComponentDefinition
  ' Material is now a hidden property
  ' Could use Document.ActiveMaterial instead
  ' see below
  MsgBox cd.Material.Name
  MsgBox d.ActiveMaterial.DisplayName
End Sub
So I think the discrepancy is only with the Ribbon UI, but I assume the iProperties would also show the correct value - e.g. inside the iProperties dialog. At least it seeemd to be that way on my side.
Cheers,
Adam Nagy
Autodesk Platform Services
