MassProperties.Mass from virtual component
pavol_krasnansky
Message 1 of 8
pavol_krasnansky
Hello
How to get MassProperties.Mass from virtual component in BOM in assembly?
Thank you
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveEditDocument
Dim oBOM As BOM
oBOM = oAsmDoc.ComponentDefinition.BOM
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item(1)
Dim oBomRow As BOMRow
Dim oCompDef As ComponentDefinition
Riadok_Tabulka_Rozpiska_Data_Modelu = -1
For i = 1 To oBOMView.BOMRows.Count
	oBomRow = oBOMView.BOMRows.Item(i)
	oCompDef = oBomRow.ComponentDefinitions.Item(1)
	If TypeOf oBomRow.ComponentDefinitions(1) Is VirtualComponentDefinition Then
		Mass_Of_Virtual_Component = Round(oBomRow.ComponentDefinitions(1).MassProperties.Mass, 3) & " kg"
		MsgBox("Mass_Of_Virtual_Component" & vbCrlf & Mass_Of_Virtual_Component)
Next
Replies (7)
Message 2 of 8
marcin_otręba
you can use mass from property set:
Dim oBOM As BOM
Dim oCompDef As VirtualComponentDefinition
    If TypeOf oCompDef Is VirtualComponentDefinition Then
        Mass_Of_Virtual_Component = Round(oCompDef.PropertySets.Item(3).Item("Mass").Value, 3) & " kg"
        MsgBox ("Mass_Of_Virtual_Component" & vbCrLf & Mass_Of_Virtual_Component)
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 8
pavol_krasnansky
Thank you, but this solution doesn't work.
Message 4 of 8
marcin_otręba
hymn, what do you mean that it doesn’t work? do you get any error? did you placed this code or modified yours? what version of inventor you use?
Message 5 of 8
marcin_otręba
i checked oit again an this line resulted error:
i corrected it:
Dim oBOM As BOM
Next
Message 6 of 8
pavol_krasnansky
Thank you. This code works without error, but result is bad. In mass isn't point.
I have Inventor Professional 2019 with last update.
Message 7 of 8
marcin_otręba
value is in grams. so you need only to divide it by 1000
Message 8 of 8
pavol_krasnansky
That did not cross my mind, because I have default unit for mass kg. Thank you for you help.
