Managing changes in Model States (iLogic)
theo_karypidis
Message 1 of 10
theo_karypidis
Model States has brought a lot of new functionality in managing the configurations of our Inventor documents, but also added a bit of complexity in passing down parameters, managing the model state we want active etc.
When we have to do with straightforward models and cases,  it's extremely simple:  Add the Model States you need, make the changes in views, iProperties and Parameters you want for each Model State and you are done.
What happens though when each Model State is not static? It is very often, for example, that we have a model that some of its parameters are ever-changing according to the customer order that we have. Sometimes the variety of a parameter value cannot be cut down to specific cases but can have hundreds of different possible values. That's where it gets complicated.
Every change we make in any model state, it is stored and set in that specific model state. And if we open the Excel spreadsheet that lists all the changes for all our Model States, we can see and manage all those changes. I found myself in such a situation recently. The following ilogic snippets are a solution to the above issue.
First, I needed a way to be able to delete that parameter column from the Excel sheet that has its values for each Model State:
Sub DeleteTableColumn(AssDoc As AssemblyDocument, oPart As String, oParam As String)
Dim Occ As Inventor.ComponentOccurrence = AssDoc.ComponentDefinition.Occurrences.ItemByName(oPart)
Dim partdoc As PartDocument = Occ.Definition.FactoryDocument
Try
partdoc.ComponentDefinition.ModelStates.ModelStateTable.TableColumns.Item(oParam).Delete
Catch
End Try
End Sub
I called the code above to the following snippets according to what I needed to do each time. If you don't need or want to delete the parameter column, just delete or comment the line that calls the above code.
The snippet below will internally activate the specified Model State and change the value of the desired parameter.
Sub setParamValueInModelState(AssDoc As AssemblyDocument, oPart As String, oModelStateName As String, oParam As String, oParamValue As Integer)
''Choose the part to make the changes
''Activates the model state to change parameter values
partdoc.ComponentDefinition.ModelStates.Item(oModelStateName).Activate()
''Delete the model state column of the specified parameter
DeleteTableColumn(AssDoc, oPart, oParam)
''Give value to specified model state and parameter
partdoc.ComponentDefinition.Parameters.UserParameters.Item(oParam).Value = oParamValue / 10
AssDoc.Update2
End Sub
The snippet below will change the value of the desired parameter in the current Model State the Part is on:
Sub setParamValueInCurrentModelState(AssDoc As AssemblyDocument, oPart As String, oParam As String, oParamValue As Integer)
''Activate master model state
'If partdoc.ComponentDefinition.ModelStates.ActiveModelState.ModelStateType = ModelStateTypeEnum.kSubstituteModelStateType Then
'   partdoc.ComponentDefinition.ModelStates.Item(1).Activate
'End If
'DeleteTableColumn(AssDoc, oPart, oParam)
End Sub
The snippet below will activate the specified Model State and change the value of the desired parameter:
Sub setParamValueInActivatedModelState(AssDoc As AssemblyDocument, oPart As String, oModelStateName As String, oParam As String, oParamValue As Integer)
''Set active model state
Occ.ActiveModelState = oModelStateName	'selects the model state
End Sub
I really hope those will help you as much as they helped me!
Replies (9)
Message 2 of 10
CattabianiI
I think it's very wrong to delete the table column for your purpose, you're loosing so much information about model states you're currently not interested into. And you're basically not leveraging model states concept. Why are you doing that?
Another related thing:
when you work on partDoc = occ.Definition.FactoryDocument, you're not necessarily affecting the occurrence*.
I don't know what are supposed to do the caller of setParamValueInActivatedModelState function but to set the parameter in your occurrence you should do something like that:
''Set desired model state in the occurrence
' Set the model state I want to work with in the factory too
' It's from the factory where you're setting the parameter
partDoc.ComponentDefinition.ModelStatesoMStates.Item(oModelStateName).Activate()
' DO NOT DO THAT
' DeleteTableColumn(AssDoc, oPart, oParam)
''Set paramete in the model state active in partDoc (the factory)
Message 3 of 10
zoe.baker-bushby
Hi!
I notice the oParamValue / 10 is this due units? Having issues with this bit myself where my only work around is this divide by 10.
So I've got it to work, just curious if there are any alternatives?
Message 4 of 10
theo_karypidis
Thank you CattabianiI I will try what you suggested!!
As for the column deletion, well you don't always want a parameter value to be set in a model state table. I am sure there must be a way that I could not find, but some parameters you need to change them for all Model States. Parameters like the length of a part that can in any case take values from 600 mm to 1400 mm with increment of 1 mm cannot be set to cases.
Message 5 of 10
theo_karypidis
Hello! Indeed, it is a units matter. It is because Inventor sees cm instead of my desired mm. It is the same if you do it from another language, outside Inventor.
Message 6 of 10
CattabianiI
Hi @zoe.baker-bushby,
as I said in the other thread check this article to have a better understanding on how to work with database units in ilogic: https://adndevblog.typepad.com/manufacturing/2012/07/unitsofmeasure-object-and-example.html
Dividing by 10 works if the length units are millimeter; it's an hardcoded way to deal with the issue I do not recommend.
Message 7 of 10
CattabianiI
hi @theo_karypidis
about column deletion.
I understand your workflow and the granularity issue but column deletion is not the way unless you want to stop to manage that parameter per model state from now on.
Set ModelStates.MemberEditScope instead to edit all members:
modelStates.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
If you have a length param set per model state, let's say:
msname: short, length: 100
msname: medium, length: 200
msname: long, length: 400
and you want to create a new part which stores 110, 200, 400 as lengths, in this case it's clearly wrong to delete the entire column.
If you want to stores 110, 210, 410 instead, it's still useless to delete the column because:
- the graphic is not up to date for each model states,
- once you deleted the column and set 110 in the param of short model state, you don't know which is the lenght in  the other model states; it would probably be the lenght of the active model state before to set the parameter so 100 and it sounds terribly wrong.
Message 8 of 10
rob
Old thread, but could you please post all the code to push an example parameter value down into a component for all of its model states (i.e. same parameter regardless of model state)?  Thanks!
IV Pro 2020.2
Message 9 of 10
CattabianiI
It's really just that line. And the operations to change param for all model states via iLogic are one-to-one with operations via UI.
So I recommend to understand very well the Toggle Edit Scope button before doing that via iLogic.
Anyway here's some code:
' Set length param in the active model state
Parameter("length") = 10
' Enable edit on all model states
Dim mss As ModelStates = ThisApplication.ActiveDocument.ComponentDefinition.ModelStates
mss.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
' Set length param
Parameter("length") = 15
' Enable edit on active model state only
mss.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
Message 10 of 10
rob
Thanks for that.  This changes the parameter for all model states in the currently active document, which is part of the solution.
What I'm really after is a way to push the value from the active assembly to a specified component in the assembly, where both have identically defined model states.  I did post a query on the forum and have a solution already, but am curious to know your approach.
IV Pro 2020.2
