Making sketches using iLogic
machiel.veldkamp
machiel.veldkamp
Hey everybody.
I'm thinking.
I'm making a lot of sketches where I'm just making a sketch with a circel on it.
Should be possible with iLogic right?
This is what I had planned.
Now. I do have a little experience in programming and even with iLogic but when it comes to forms and windows. Well.
I could use some help!
Where do I begin?
___________________________
machiel.veldkamp
What I have so far:
'  a reference to the currently active document.
' This assumes that it is a part document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'  a reference to the component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
'  a reference to the transient geometry object.
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim doc = ThisApplication.ActiveDocument
Dim oLijn = ThisApplication.CommandManager.Pick(
	SelectionFilterEnum.kSketchCurveLinearFilter,
	"Select a line")
Dim oPunt = ThisApplication.CommandManager.Pick(
	SelectionFilterEnum.kSketchDefaultFilter,
	"Select Point")
' Create a work plane at the end of the 2D sketch.
Dim oWP As WorkPlane
oWP = oCompDef.WorkPlanes.AddByNormalToCurve _
(oLijn, oPunt)
' Create a sketch on the Workplane
oSketch = oCompDef.Sketches.Add(oWP)
oOrigin = oSketch.ModelToSketchSpace(oTG.CreatePoint(0, 0, 0))
oSketch.SketchCircles.AddByCenterRadius(oOrigin, 5)
machiel.veldkamp
Alright!
I think I have it!
I want to complete it with a window that asks what geometry and sizes etc to choose. But for version 0.1 this is alright!
Dim oLijn = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Select a line")
Dim oPunt = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select Point")
oWP = oCompDef.WorkPlanes.AddByNormalToCurve(oLijn, oPunt)
oWP.Visible() = False
Dim oRadius
oDiameter = InputBox("What is the DIAMETER?", "Prompt user for dimensions", "0 ")
If oDiameter = 0
	oDiameter = 10
oRadius = oDiameter/20
oRefpunt = oSketch.AddByProjectingEntity(oPunt)
Dim oSketchCircle As SketchCircle
oSketchCircle = oSketch.SketchCircles.AddByCenterRadius(oRefPunt, oRadius)
oSketch.GeometricConstraints.AddCoincident(oRefPunt, oSketchCircle.CenterSketchPoint)
'oSketch.DimensionConstraints.AddDiameter(oSketchCircle.ContainingSketchBlock, 0 )
Dim DimC As DimensionConstraint
	DimC = oSketch.DimensionConstraints.AddDiameter(oSketchCircle, oTG.CreatePoint2d(0, 1), False)
machiel.veldkamp
Version 0.2
Lot's of improvements!
Public Sub Main()
    oChoose
End Sub
Dim oLine
Dim oPoint
Dim oDiameter As String
Public Sub oChoose()
    oPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select Point")
    oLine = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Select a line")
    oDiameter = InputBox("What is the DIAMETER? NOTE:", "Prompt user for dimensions")
    oDiameter = oDiameter.Replace(".", ",")
    oExecute
End Sub
Public Sub oExecute()
        oWP = oCompDef.WorkPlanes.AddByNormalToCurve(oLine, oPoint)
    ' Creates a reference point from oPoint on "0, 0"
    oRefpunt = oSketch.AddByProjectingEntity(oPoint)
    oDiameter /= 20R
    'AddByCenterRadius is in cm!!!
    oSketchCircle = oSketch.SketchCircles.AddByCenterRadius(oRefPunt, oDiameter)
        InventorVb.DocumentUpdate()
End Sub
RoyWickrama_RWEI
Interesting!
I would like to know what does the following part in the code do:
machiel.veldkamp
If the user enters "10,2" this will convert the input to "10.2"
