Make my updated input message box results show in message
tracey_prior8CZVC
tracey_prior8CZVC
I have code that looks for a multi value List parameter on a drawing called Notes, and adds it if missing.  Then allows me to add to the multivalue list from an input message box.  Now I want the list to show in a message box.  I only manage to see the list  minus the just inputted.  Plus I want the list to stay up until I close it.
This is a running tally of to do task until first issue.
Dim drawDoc As DrawingDocument = ThisDoc.Document
Dim drawParams As UserParameters = drawDoc.Parameters.UserParameters
Dim testParam As UserParameter
Try
	testParam = drawParams.Item("Notes")
Catch
	testParam = drawParams.AddByValue("Notes" , "My Notes", UnitsTypeEnum.kTextUnits)
End Try
	MultiValue.SetList("Notes", "My Notes")
	'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
	Dim List As New ArrayList
List = MultiValue.List("Notes")
Dim msg1 As String = vbCrLf & vbCrLf
For Each sVal As String In List
	msg1 += "" & sVal & vbCrLf
Next
Dim val As String = InputBox("Write your note. Available Notes: " & msg1, "Adding Note to List",)
MessageBox.Show(msg1)
If val = Nothing Then Exit Sub
	If List.Contains(val) = False Then List.Add(val)
MultiValue.List("Notes") = List
Curtis_Waguespack
Hi @tracey_prior8CZVC
Welcome to the forums. Give this version a try.
I hope this helps.
Curtis
Try
Catch
	testParam = drawParams.AddByValue("Notes", "My Notes", UnitsTypeEnum.kTextUnits)
End Try
Next
Dim val As String = InputBox("Write your note. Available Notes: " & msg1, "Adding Note to List", )
msg1 = Nothing
Next
tracey_prior8CZVC
Thank you Curtis, this works perfectly 🙂
