Make feature sketch invisible in an assembly
Hubert_Los
Hubert_Los
How to make invisible all the feature sketches that are make visible in the assembly?
Andrii_Humeniuk
Hi @Hubert_Los . Try this iLogic code. It makes all sketches in all components of the main assembly invisible.
Private Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "SetVisibleSketch")
	For Each oRefDoc As Document In oDoc.AllReferencedDocuments
		If TypeOf oRefDoc Is PartDocument And oRefDoc.IsModifiable Then
			Dim oPDoc As PartDocument = oRefDoc
			Call SetVisibleSketch(oPDoc.ComponentDefinition.Sketches)
	Next
	oTrans.End()
End Sub
Private Function SetVisibleSketch(oSkets As PlanarSketches, Optional bVisible As Boolean = False)
	For i As Integer = 1 To oSkets.Count
		If oSkets.Item(i).Visible Then oSkets.Item(i).Visible = bVisible
	Next
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Hubert_Los
Hi @Andrii_Humeniuk ,
Unfortunately your code only works on "shered skeches" I have a different situation. I enable sketch editing from the assembly level and this sketch is not share.
Andrii_Humeniuk
Not sure I understood you correctly, but made the changes to the code. Now the visibility of sketches is turned off in the main assembly and in subassemblies and in details. The code also includes a check for the ability to modify documents.
Private Sub Main()
	If oDoc.IsModifiable Then Call SetVisibleSketch(oDoc.ComponentDefinition.Sketches)
		If oRefDoc.IsModifiable Then
			Call SetVisibleSketch(oRefDoc.ComponentDefinition.Sketches)
	Next
	oTrans.End()
End Sub
		On Error Resume Next
	Next i
End Function
Hubert_Los
Sorry, but it doesn't work. I'm sending a video of what sketch I mean
(view in My Videos)
Andrii_Humeniuk
Hi @Hubert_Los . I finally understood you. Thanks for the video explaining what you need it really helped. Here is the code that determines the visibility of all proxy skeaths and makes them invisible:
Private Sub Main()
	Call SetVisibleSketch(oDoc.ComponentDefinition.Occurrences)
	oTrans.End()
End Sub
Private Function SetVisibleSketch(oOccs As ComponentOccurrences, Optional bVisible As Boolean = False)
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
			Dim oOccDef As PartComponentDefinition = oOcc.Definition
			For Each oSketch As PlanarSketch In oOccDef.Sketches
				Dim oSketchProxy As PlanarSketchProxy : oOcc.CreateGeometryProxy(oSketch, oSketchProxy)
				If oSketchProxy.Visible Then oSketchProxy.Visible = False
			Next
		Else If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			If oOcc.SubOccurrences.Count > 0 Then
				Call SetVisibleSketch(oOcc.SubOccurrences)
	Next
End Function
Hubert_Los
Now it works, thank you 🙂
