Make a code work for only active sheet, not all sheets.
Hi. I have 2 codes. They work beautifully, however they work on all sheets and I just want them to work on the active sheet. Someone who can help me edit the codes?
Code 1 (Delete Scale)
For Each oSheet As Sheet In ThisDrawing.Document.Sheets
	For Each oView As DrawingView In oSheet.DrawingViews
		oView.Label.FormattedText = oView.Label.FormattedText.Replace("<DrawingViewScale/>", "").Replace("(", "").Replace(")", "")
	Next
Next
Code 2 (Delete Border)
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveEditDocument
Dim oCurrentNumber  As Sheet
oCurrentNumber = oDoc.ActiveSheet
' Iterate through the sheets, and delete the title blocks and symbols
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    oSheet.Activate
    Try
    oSheet.Border.Delete
    Catch
    'catch error if no border found
    End Try
Next
Accepted solutions (3)
JhoelForshav
Hi @Anonymous
Seems like this should do it?
Rule 1:
For Each oView As DrawingView In ActiveSheet.Sheet.DrawingViews
Next
Rule 2:
Try
ActiveSheet.Sheet.Border.Delete
Catch
End Try
Martin-Winkler-Consulting
@Anonymous
This should work:
'Code1
Sub DeleteScale()
 Dim oActiveSheet As Sheet
 oActiveSheet = oDoc.ActiveSheet
	For Each oView As DrawingView In oActiveSheet.DrawingViews
	Next
End Sub
'Code2
Sub DeleteBorder()
	Try
     oActiveSheet.Border.Delete
    Catch
    End Try
End Sub
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Perfect! Thank you both. Appreciate your help!
