Macros: Point Snaps in Sketch
ryabinina_olya
ryabinina_olya
Hello!
I use the command "Point Snaps - Endpoint" from the context menu. How I can call this command in Macros?GTpsjD4K8_0.jpg
Can someone help me with this?
Olga Ryabinina
Professor Assistant in Voronezh State Technical University
A.Acheson
For future post if you put the request in the customization forum you might have more users familiar with programming questions and trouble shooting etc.
Searching for the right command can be hit and miss, look at the command name and search for it using notepad find method. When activating the command ensure you are in the right area where the command is exposed.
Here is how you run a command and also how to get the command list similar to below https://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
https://clintbrown.co.uk/2020/03/14/ilogic-running-commands-using-the-api/amp/
This is what the command list will look like. Search endpoint, found correct snippet see picture.
https://github.com/AlexFielder/iLogic/blob/master/CommandNames.txt
Here is ilogic version.
Dim oCDs As ControlDefinitions
 oCDs = ThisApplication.CommandManager.ControlDefinitions
Dim oCD As ControlDefinition
 oCD = oCDs("GetPointEndpoint")
'test to see we have the correct button 'oCD.Enabled = True Is active In Right Click Context Menu ' oCD.Enabled = False Is greyed out and deactivated In Right Click Context Menu
'launch command oCD.Execute
Regards
Alan
ryabinina_olya
Thanks!
It works, but I need code for macros, because I want use it in hot key
Olga Ryabinina
A.Acheson
First sub in this article posted previously. Replace command as needed.
Public Sub RunLineCommand()
    ' Get the CommandManager object.
    Dim oCommandMgr As CommandManager
    Set oCommandMgr = ThisApplication.CommandManager
    ' Get control definition for the line command.
    Dim oControlDef As ControlDefinition
    Set oControlDef = oCommandMgr.ControlDefinitions.Item("GetPointEndpoint")  ‘place command here
    ' Execute the command.
    Call oControlDef.Execute
End Sub
Regards
Alan
