Macro Runs - But not when Hot Key is used
RNDinov8r
RNDinov8r
So, I used the code found here with super minor modifications: https://forums.autodesk.com/t5/inventor-customization/inventor-pro-2014-ilogic-assign-a-keystroke-to... and the method described in message 4 of 4 to set up my hotkey and create the "macro".
My iLogic Code works correctly (changes dim styles) and the macro runs correctly when I run it thru the macro menu under the Tools Tab.
When I initially run the macro, I get this error
But if I manually run the rule once, I don't get the error when I run the macro.
Someone suggested changing:  iLogicAuto.RunExternalRule oDoc, RuleName to  iLogicAuto.RunRule oDoc, RuleName
but that had no effect.
Once I do get it working, I have an assigned Hot Key and it works as well.
This is the Module in my Main VB Project:
Public Sub HoleDimStyle() '<--- This is what you would tie to a button in a toolbar.
  RuniLogic "HoleDimeStyle" 'there was a type that is why it is Dime and not Dim...
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
  Dim iLogicAuto As Object
  Dim oDoc As Document
  Set oDoc = ThisApplication.ActiveDocument
  If oDoc Is Nothing Then
    MsgBox "Missing Inventor Document"
    Exit Sub
  Set iLogicAuto = GetiLogicAddin(ThisApplication)
  If (iLogicAuto Is Nothing) Then Exit Sub
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Set addIns = oApplication.ApplicationAddIns
'Find the add-in you are looking for
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then Exit Function
addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
I have verified multiple times, that external iLogicRule is loading correctly..i.e. it "exists" in the document before I run the macro.
TechInventor20
Sub HoleDimStyle()
Debug.Print "*Reset k factor* start!"
Dim RuleName As String
'**************Location of the Rule you want to use + rule name
RuleName = Inventor_zoeklocatie & "AuTTeK\Orginele bestanden\Reset_kfactor.iLogicVb" 'ilogic regel
'*****this lets the rule run
Dim Fname3 As String
Dim RuleName2 As String
Fname3 = ThisApplication.ActiveDocument.fullfilename
If Fname3 = "" Then
MsgBox "Document eerst opslaan"
Exit Sub
Debug.Print Fname3
Call RunRule1(Fname3, RuleName)
'***** updaten *****
Line_update:
ThisApplication.ActiveView.Update
ThisApplication.ActiveDocument.Update
Debug.Print "*Reset k factor* EIND!"
End Sub
