macro icon text wrap
skyngu
skyngu
hi
I created some marcon icons in ribbon bar by using "customize user commands".
I place them on ribbon and they are working fine. In inventor 2011, I select large icon and text display.
Can I wrap the text under icon? how can I do that?
does it work with "ctr(13) & ctr (10)"?
thanks a lot!!
spec inventor 2011 sp2 & window 7
Autodesk Inventor Professional 2019
ACEDeSmedt
Maybe vbNewLine or \r\n
What you can do is create a kind of shortcut macro with a shorter name that fires the macro you need
If this is the solution, push the solution button 😉 (and maybe some kudos)
Autodesk Product Design Suit - Ultimate edition (Subscription)
skyngu
please check attachment.
I wrap the macro's name like "bill of materials". is it possible by vba instead of addin?
thanks
ACEDeSmedt
I don't think this can be done.
Mainly because the name underneath the icon is the macro name itself and you are not allowed to use spaces or other special characters.
Klaas De Smedt
skyngu
thanks for your reply.
 I check property of display name is read-only in object browser.
Bumping this to see if there are any changes relevant to Inventor Pro 2019. Can we wrap the text of a macro in the ribbon?
Tighe
