Macro for Automating Assembly
Message 1 of 10
Can we Make code for Selecting Part Automatically?
Replies (9)
Message 2 of 10
Hello mate,
The Inventor Developer's Help File contains samples for adding part files in to an assembly, including the code to mate relative to other parts. I would recommend you mate to planes, as I find these easier to locate within a part.
Jon
Message 3 of 10
Dear Jon,
Thanks for your reply.
I've gone thru the Sample files, the problem I'm facing here is for each program, we need to select the Part in the assembly before running macro, i want to make it auomated... As I'm following Standard part name, I can identify the part with their name, and insted of asking user to select the part, I want to select these part in run time... Can you help me in auomating the 'Selection' part? that will be a great help to novice like me.
With warm regards
Sumit
Message 4 of 10
ludesroc
Here is a brief exemple...Have an assy doc opened and run this code. The code will stop after selecting the first occurence in the browser. Press F5 the continue.
Sub SelectComponent()
Dim oAssy As AssemblyDocument
Set oAssy = ThisApplication.ActiveDocument
Dim oAssyCompDef As AssemblyComponentDefinition
Set oAssyCompDef = oAssy.ComponentDefinition
Dim oSelSet As SelectSet
Set oSelSet = ThisApplication.ActiveDocument.SelectSet
Dim oOcc As ComponentOccurrence
Set oOcc = oAssyCompDef.Occurrences.Item(1)
Call oSelSet.Select(oOcc)
' Do whatever here
Stop
oSelSet.Clear
Set oSelSet = Nothing
End Sub
Ludesroc.
Ludesroc
Message 5 of 10
Ehup mate,
Are you trying to add parts to an assembly, or identify them within an assembly? I'm a touch confused as to what you are aiming for? Edited by: jonbrabbs on Sep 17, 2009 12:51 PM
Message 6 of 10
Thank you Jonbrabbs,
Let me check this piece of code, if I have any doubt I'' trouble you again..
Message 7 of 10
Hello Dear,
I'm trying to add parts from pre-defined location, and the trying to constrain them.. basically I'm trying for 3 Cylindrical part with same Diameter but with different Material & Stock Number.
So I know How to add the part in assembly, but I'm not sure How to constrain them without asking user to select these parts.
as these are cylinder, we can very well constrain them with 'insert' & Plain constrain. Please help me in this regard
Message 8 of 10
ludesroc
I suggest you use iMate.
Look for...
1) Create an iMate --> Help Menu
2) iMate Using Entities -->Programming Help Menu Samples
Ludesroc
Ludesroc
Message 9 of 10
Ehup mate,
If you're putting the parts in using code, here is something I wrote in .NET to mate Planes and Axes
Sub AddAngleConstraint(ByVal EntityOne As Object, ByVal EntityTwo As Object, ByVal Offset As Double, ByVal strMateType As String, _
ByVal Axis1 As Integer, ByVal Axis2 As Integer)
On Error GoTo ErrH
oOcc1 = EntityOne
oOcc2 = EntityTwo
oPartAxis1 = oOcc1.Definition.workaxes.item(Axis1)
oPartAxis2 = oOcc2.Definition.workaxes.item(Axis2)
Call oOcc1.CreateGeometryProxy(oPartAxis1, oAsmAxis1)
Call oOcc2.CreateGeometryProxy(oPartAxis2, oAsmAxis2)
Select Case strMateType
Case "Flush"
Call oAsmCompDef.Constraints.AddFlushConstraint(oAsmAxis1, oAsmAxis2, Offset)
Case "Mate"
Call oAsmCompDef.Constraints.AddMateConstraint(oAsmAxis1, oAsmAxis2, Offset)
Case "Angle"
Call oAsmCompDef.Constraints.AddAngleConstraint(oAsmAxis1, oAsmAxis2, Offset)
Case "Special"
oPartPlane1 = oOcc1.Definition.workplanes.item(Axis1)
Call oOcc1.CreateGeometryProxy(oPartPlane1, oAsmPlane1)
Call oAsmCompDef.Constraints.AddMateConstraint(oAsmPlane1, oAsmAxis2, Offset)
End Select
ErrH:
End Sub
Public Sub AddMateConstraint(ByVal EntityOne As Object, ByVal EntityTwo As Object, ByVal Offset As Double, ByVal strMateType As String, _
ByVal Plane1 As Integer, ByVal Plane2 As Integer)
On Error Resume Next
oOcc1 = EntityOne
oOcc2 = EntityTwo
oPartPlane1 = oOcc1.Definition.workplanes.item(Plane1)
oPartPlane2 = oOcc2.Definition.workplanes.item(Plane2)
Call oOcc2.CreateGeometryProxy(oPartPlane2, oAsmPlane2)
Case "Flush"
Call oAsmCompDef.Constraints.AddFlushConstraint(oAsmPlane1, oAsmPlane2, Offset)
Case "Mate"
Call oAsmCompDef.Constraints.AddMateConstraint(oAsmPlane1, oAsmPlane2, Offset)
End Select
End Sub
These are called from the main sub by the following code
AddMateConstraint(BackPanel(c), BackPanel(c - 1), -0.45, "Flush", 1, 1)
AddMateConstraint(BackPanel(c), BackPanel(c - 1), (((-panelheight(i - 1)) / 10) / 2) + (((-panelheight(i)) / 10) / 2) - 1.3, "Flush", 2, 2)
AddMateConstraint(BackPanel(c), BackPanel(c - 1), 0, "Flush", 3, 3)
Where BackPanel(c) is component 1 and backpanel(c-1) is the second component.
BackPanel(c) = oOccs.AddiPartMember("S:\Design\Drawings\Library\Components\Gondola\Back Panel.ipt", oPos, iNumRows)
To add using iMAtes through code, you could use something like:
oOccEnumerator = oAsmCompDef.Occurrences.AddUsingiMates("S:\Design\Drawings\Library\Components\Gondola\Tek Fixing.ipt", True)
This will add parts to all available iMate locations (In this case 16 places). Changing to False, will add one occurrence in.
for you, it would look something like:
oOccEnumerator = oASmCompDef.Occurrences.AddUsingiMates("Cylinder.ipt", False)
Jon
Message 10 of 10
By ilogic - commandmanager, i would like to pick the part and use your function to make constraint.
SubMain()
EntityOne=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter ,"Select Entities -1 to constraints:")
EntityTwo=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter ,"Select Entities -2 to constraints:")
AddMateConstraint(EntityOne,EntityTwo, 0, "Flush", 3, 3)
End Sub
On Error Goto ErrH
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oOcc1 = EntityOne
oOcc2 = EntityTwo
Case "Flush"
Case "Mate"
Case "Angle"
Case "Special"
End Select
ErrH:
End Sub
oOcc1 = EntityOne
oOcc2 = EntityTwo
Case "Flush"
Case "Mate"
End Select
End Sub
Can you help me to select correct "SelectionFilterEnum" for your function code
'Public Enum SelectionFilterEnum
'kPartEdgeFilter = 15873
'kPartEdgeCircularFilter = 15874
'kPartEdgeLinearFilter = 15875
'kPartEdgeMidpointFilter = 15876
'kPartFaceFilter = 15877
'kPartFacePlanarFilter = 15878
'kPartFaceCylindricalFilter = 15879
'kPartFaceConicalFilter = 15880
'kPartFaceToroidalFilter = 15881
'kPartFaceSphericalFilter = 15882
'kPartVertexFilter = 15883
'kPartFeatureFilter = 15884
'kPartSurfaceFeatureFilter = 15885
'kPartBodyFilter = 15890
'kPartDefaultFilter = 15886
'kSketchDimConstraintFilter = 16128
'kSketchCurveFilter = 16129
'kSketchCurveLinearFilter = 16130
'kSketchCurveCircularFilter = 16131
'kSketchCurveEllipseFilter = 16132
'kSketchCurveSplineFilter = 16133
'kSketchPointFilter = 16134
'kSketchDefaultFilter = 16135
'kSketchObjectFilter = 16136
'kSketchImageFilter = 16137
'kSketchTextBoxFilter = 16138
'kSketchProfileFilter = 16139
'kSketchProjectedCutFilter = 16140
'kSketchBlockDefinitionFilter = 16141
'kSketchBlockFilter = 16142
'kSketch3DCurveFilter = 17664
'kSketch3DCurveLinearFilter = 17665
'kSketch3DCurveCircularFilter = 17666
'kSketch3DCurveEllipseFilter = 17667
'kSketch3DCurveSplineFilter = 17668
'kSketch3DPointFilter = 17669
'kSketch3DDefaultFilter = 17670
'kSketch3DObjectFilter = 17671
'kSketch3DDimConstraintFilter = 17672
'kSketch3DProfileFilter = 17673
'kWorkAxisFilter = 16384
'kWorkPlaneFilter = 16385
'kWorkPointFilter = 16386
'kUserCoordinateSystemFilter = 16387
'kAssemblyOccurrenceFilter = 16640
'kAssemblyLeafOccurrenceFilter = 16643
'kAssemblyOccurrencePatternFilter = 16644
'kAssemblyOccurrencePatternElementFilter = 16645
'kAssemblyFeatureFilter = 16646
'kAllPlanarEntities = 18432
'kAllLinearEntities = 18433
'kAllPointEntities = 18434
'kAllCircularEntities = 18435
'kAllCustomGraphicsFilter = 18436
'kCustomBrowserNodeFilter = 18437
'kFeatureDimensionFilter = 18438
'kAllEntitiesFilter = 18439
'kDrawingDefaultFilter = 16896
'kDrawingSheetFilter = 16897
' kDrawingViewFilter = 16898
' kDrawingNoteFilter = 16899
'kDrawingDimensionFilter = 16900
'kDrawingPartsListFilter = 16901
'kDrawingHoleTableFilter = 16902
'kDrawingHoleTagFilter = 16903
'kDrawingRevisionTableFilter = 16904
'kDrawingCustomTableFilter = 16905
'kDrawingBalloonFilter = 16906
'kDrawingSketchedSymbolFilter = 16907
'kDrawingSketchedSymbolDefinitionFilter = 16908
'kDrawingAutoCADBlockFilter = 16922
'kDrawingAutoCADBlockDefinitionFilter = 16923
'kDrawingBorderDefinitionFilter = 16909
'kDrawingTitleBlockDefinitionFilter = 16910
'kDrawingBorderFilter = 16913
'kDrawingTitleBlockFilter = 16912
'kDrawingCurveSegmentFilter = 16914
'kDrawingCenterlineFilter = 16915
'kDrawingCentermarkFilter = 16916
'kDrawingSheetFormatFilter = 16917
'kDrawingFeatureControlFrameFilter = 16918
'kDrawingSurfaceTextureSymbolFilter = 16919
'kDrawingOriginIndicatorFilter = 16920
' kDrawingViewLabelFilter = 16921
End Enum
