Macro delete project geometry in sketch
Hello.
I wish to delete all project geometry in the active drawingsketch with 1 click
But unsure how to get to these constraints.
Are these geometricConstraints?
What I have now doesnt work:
Select Case ThisDoc.Document.DocumentType
Case 12292:
Case Else: MsgBox("Current Document not a drawing document")
Exit Sub
End Select
If Not TypeOf ThisApplication.ActiveEditObject Is Sketch Then
MsgBox("Please activate a sketch")
Exit Sub
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSketch As Inventor.DrawingSketch = ThisApplication.ActiveEditObject
Dim oGeos As GeometricConstraints = OSketch.GeometricConstraints
Dim oGeo As GeometricConstraint
For Each oGeo In oGeos
oGeo.delete
Next
What am I doing wrong?
Thx in advance,
Arnold
you can check if SketchEntity.ReferencedEntity is nothing to see if its referenced geometry, but I'm fairly certian that you cannot delete referenced geometry with SketchEntity.Delete() method.
Yes, I have tried that method, but I also can't find how to delete the projected geometry constraints
philippe.leefsma
 Hi Arnold,
There is no constraints for projected geometry. So as our friend Robert mentioned, iterate through the sketch entities to find the ones that have a ReferencedEntiy, which mean they are projected. Then simply call Delete on those sketch entities.
Philippe.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
rohitchavan123
Hi Philippe,
Simply calling delete on sketch entity is giving exception in API.
I tried BreakLink() on sketch also but it also give exception.
Looks like deleting Projected Loop is tricky one.
Rohit
