[Macro] Create rectangle and center it to main projected planes with symetric constrain
amarcoc
Message 1 of 10
amarcoc
Hi.
I am trying to make a macro (iLogic or VBA) that generates a rectagle, simetrical to main planes.
Here are the steps:
1) Create new sketch [DONE]
2) Select Plane [DONE]
3) Project all main planes [DONE]
4) Create a rectangle [DONE]
5) Center rectangle with symetric constrain
Can anyone help me on the missing points? Assuming I am already inside a sketch, I only need the create rectangle and center it.
Thanks in advance!!!
EDIT: Here is the code used to create the rectangle. How do I center it to main planes? It's the only thing missing. Thanks!
Dim oCompDef As PartComponentDefinition
oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim planeXY = oCompDef.WorkPlanes.Item(3)
Dim my_sketch As PlanarSketch
my_sketch = oCompDef.Sketches.Add(planeXY)
my_sketch.OriginPoint = oCompDef.WorkPoints.Item(1)
my_sketch.Edit
'PROJECT PLANES
Dim oPartDoc As PartDocument
Dim oAssyDoc As AssemblyDocument
Dim oSelectSet As SelectSet
Select Case ThisApplication.ActiveDocument.DocumentType
	Case kPartDocumentObject
		oPartDoc = ThisApplication.ActiveDocument
		oSelectSet = oPartDoc.SelectSet
		oSelectSet.Clear
		For Each oWorkPlane In oPartDoc.ComponentDefinition.WorkPlanes
			oSelectSet.Select(oWorkPlane)
		Next
	Case kAssemblyDocumentObject
		oAssyDoc = ThisApplication.ActiveDocument
		oSelectSet = oAssyDoc.SelectSet
		For Each oWorkPlane In oAssyDoc.ComponentDefinition.WorkPlanes
		Next
End Select
ThisApplication.CommandManager.ControlDefinitions.Item("AppProjectGeometryWrapperCmd").Execute
ThisApplication.CommandManager.StopActiveCommand
Dim Width As Integer = 40
Dim Height As Integer = 80
Dim tg As Inventor.TransientGeometry = ThisApplication.TransientGeometry
Dim lines As Inventor.SketchLines = my_sketch.SketchLines
Dim points As Inventor.SketchPoints = my_sketch.SketchPoints
Dim point_array(3) As Inventor.SketchPoint
point_array(0) = points.Add(tg.CreatePoint2d(-Width/2, -Height/2), False)
point_array(1) = points.Add(tg.CreatePoint2d(Width/2, -Height/2), False)
point_array(2) = points.Add(tg.CreatePoint2d(Width/2, Height/2), False)
point_array(3) = points.Add(tg.CreatePoint2d(-Width/2, Height/2), False)
'Draw lines
Dim line0 = lines.AddByTwoPoints(point_array(0), point_array(1))
Dim line1 = lines.AddByTwoPoints(point_array(1), point_array(2))
Dim line2 = lines.AddByTwoPoints(point_array(2), point_array(3))
Dim line3 = lines.AddByTwoPoints(point_array(3), point_array(0))
'constrain geometry
Dim constr As Inventor.GeometricConstraints
constr = my_sketch.GeometricConstraints
'horizontal constraints
constr.AddHorizontal(line0)
constr.AddHorizontal(line2)
'vertical constraints
constr.AddVertical(line1)
constr.AddVertical(line3)
'equal constraints
constr.AddEqualLength(line0, line1)
'Add Dimensions
my_sketch.DimensionConstraints.AddOffset(line0, line2.StartSketchPoint, tg.CreatePoint2d(5, 2), False, False)
ThisApplication.CommandManager.ControlDefinitions.Item("SketchHideAllConstraintsCtxCmd").Execute
Replies (9)
Message 2 of 10
JhoelForshav
Hi @amarcoc
I'm guessing the sketch is on one of the coordinate system planes and you want to constrain the rectangle to the other two?
Try this 🙂
If Not TypeOf ThisApplication.ActiveEditObject Is PlanarSketch Then
	MessageBox.Show("A sketch must be active.", "iLogic")
	Return
Dim oSketch As PlanarSketch = ThisApplication.ActiveEditObject
Dim oTransGeom As TransientGeometry = ThisApplication.TransientGeometry
Dim Height As Integer = 40
' Create a rectangle
Dim oRectangleLines As SketchEntitiesEnumerator
oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle( _
oTransGeom.CreatePoint2d(-Width / 2, -Height / 2), _
oTransGeom.CreatePoint2d(Width / 2, Height / 2))
For i = 1 To 3
	Dim oPlane As WorkPlane = ThisDoc.Document.ComponentDefinition.WorkPlanes(i)
	If oPlane.IsCoordinateSystemElement AndAlso oPlane IsNot oSketch.PlanarEntity
		'Project the plane
		Dim wpLine As SketchLine = oSketch.AddByProjectingEntity(oPlane)
		wpLine.Construction = True
		'Get the two lines that are parallell to the projected plane
		Dim oLines As IEnumerable(Of SketchLine) = oSketch.SketchLines.OfType(Of SketchLine).Where(Function(t As SketchLine) _
		t IsNot wpLine AndAlso t.Geometry.Direction.IsParallelTo(wpLine.Geometry.Direction))
		'Create symmetric constraint
		oSketch.GeometricConstraints.AddSymmetry(oLines(0), oLines(1), wpLine)
Next
iLogicVb.UpdateWhenDone = True
Message 3 of 10
amarcoc
Wow!!!
That is perfect. One final request:  How can I add X and Y dimension between lines (not points)?
EDIT: And also, how can I hide all constrains after creation?
Message 4 of 10
JhoelForshav
@amarcoc
To set dimension between sketchlines, use DimensionConstraints.AddOffset:
	Return
For i = 1 To 3
		'Project the plane
		Dim oTextPoint As Point2d
		oTextPoint = oSketch.ModelToSketchSpace(ThisDoc.Document.ComponentDefinition.WorkPoints(1).Point)
		Dim oVector As Vector2d = oLines(0).Geometry.Direction.AsVector
		oVector.ScaleBy(oLines(0).Length / 2 * 1.05)
		oTextPoint.TranslateBy(oVector)
		oSketch.DimensionConstraints.AddOffset(oLines(0), oLines(1), oTextPoint, False)
Next
Message 5 of 10
amarcoc
Thank you!
Is it possible to auto-hide all the generated constrains? (same as F9 shortcut)
Message 6 of 10
amarcoc
Also, can I input dimension value when it is created?
Message 7 of 10
JhoelForshav
I couldn't find a way to hide constraints other than through the commandmanager. I hope thats ok.
To change the dimension value, you actually change the model parameter tied to the dimension constraint.
See example below:
	Return
For i = 1 To 3
		'Project the plane
		Dim oOffset As OffsetDimConstraint = oSketch.DimensionConstraints.AddOffset(oLines(0), oLines(1), oTextPoint, False)
		'Set parameter value
		oOffset.Parameter.Expression = "30 mm"
Next
'Let the application process queue
ThisApplication.UserInterfaceManager.DoEvents()
'Hide all constraints
Message 8 of 10
amarcoc
Thank you. 😃
That way, I define a square. Any way to define Width different than Height?
Message 9 of 10
JhoelForshav
@amarcoc
See example below:
	Return
Dim oXParam As Inventor.Parameter
Dim oYParam As Inventor.Parameter
For i = 1 To 3
		'Project the plane
		If DoubleForEquals.IsEqual(oVector.X, 0) Then oXParam = oOffset.Parameter
		If DoubleForEquals.IsEqual(oVector.Y, 0) Then oYParam = oOffset.Parameter
Next
oXParam.Expression = "100 mm"
oYParam.Expression = "50 mm"
Message 10 of 10
amarcoc
Thank you. That is perfect now 🙂
