m_DialogEvents_OnFileSaveDialog - Get "Document SubType Name"
isocam
isocam
Can anybody help?
I am creating a Vb.Net "AddIn", for Autodesk Inventor.
I need to know, for testing purposes, the "Document SubType Name" of a part, or assembly and display it in a MsgBox prior to actually saving the part or assembly.
This "Document SubType Name" could be "Assembly", "Modelling" or "Sheet Metal"
Does anybody know how I can achieve this??
Many thanks in advance!
Darren
JelteDeJong
When saving a file I expect that you are saving the active document. In that case you can get the document of the Inventor.Application object. Something like this.
Dim doc as Document = InventorApp.ActiveDocument
For getting the correct (sub)Document type you should see this post "Inventor document sub-types" It contains a very good example.
Jelte de Jong
Blog: hjalte.nl - github.com
