loss of model attributes in the drawing
anton.gorschnev
anton.gorschnev
When I try to set the size on the hole, I can't find curves by the assigned attribute in the model. The problem occurs on a section view. Tell me the solution to the problem.
Sub count1()
Dim oDrDoc As DrawingDocument
Set oDrDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrDoc.ActiveSheet
Dim oView As DrawingView
'Выбор вида
Set oView = oSheet.DrawingViews.Item(2)
Dim oPartDoc As PartDocument
Set oPartDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
'Debug.Print (oPartDoc.AttributeManager.FindObjects("Flange", "Face", "Hole").Count)
Debug.Print (oPartDoc.AttributeManager.FindObjects("Flange", "ExtrudeFeature", "Hole").Count)
'Debug.Print (oView.DrawingCurves(oPartDoc.AttributeManager.FindObjects("Flange", "Face", "Hole").Item(1)).Count)
Debug.Print (oView.DrawingCurves(oPartDoc.AttributeManager.FindObjects("Flange", "ExtrudeFeature", "Hole").Item(1)).Count)
Dim oDCurve1 As DrawingCurve
Dim oRed As Color
Set oRed = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
For i = 1 To oView.DrawingCurves(oPartDoc.AttributeManager.FindObjects("Flange", "ExtrudeFeature", "Hole").Item(1)).Count
Set oDCurve1 = oView.DrawingCurves(oPartDoc.AttributeManager.FindObjects("Flange", "ExtrudeFeature", "Hole").Item(1)).Item(i)
oDCurve1.Color = oRed
Next
End Sub
mdavis22569
Can you share an example file?
Mike Davis
anton.gorschnev
https://yadi.sk/d/ASTEx6x0Qm9Khw
This problem occurs when the hole for fasteners falls on the chamfer. I solved the first problem by changing the depth of the cut. But the problem reappeared in the next step (code below).
Sub count1()
Dim oSheet As Sheet
Set oView = oSheet.DrawingViews.Item(1)
Debug.Print (oPartDoc.AttributeManager.FindObjects("Flange", "Uplotnitel", "EndB").Count)
Debug.Print (oView.DrawingCurves(oPartDoc.AttributeManager.FindObjects("Flange", "Uplotnitel", "EndB").Item(1)).Count)
Dim oRed As Color
Set oRed = ThisApplication.TransientObjects.CreateColor(255, 0, 255)
For i = 1 To oView.DrawingCurves(oPartDoc.AttributeManager.FindObjects("Flange", "Uplotnitel", "EndB").Item(1)).Count
Set oDCurve1 = oView.DrawingCurves(oPartDoc.AttributeManager.FindObjects("Flange", "Uplotnitel", "EndB").Item(1)).Item(i)
Next
End Sub
anton.gorschnev
A problem of this nature occurs on all my parts when changing the geometry so that the existing groove, the hole partially begins to fall on another surface. Here is another example. If the bracket hole hits the bending surface, the curves in the drawing are not located through the attributes. Link to the document below.скоба.pnghttps://disk.yandex.ru/d/wKQVMHitCLBQDw
