Loops not looping without a messagebox
loicLPQZG
loicLPQZG
Hello all,
I have a bit of a silly question as i don't have a strong background in programming.
I try to loop through center marks to add breaks withing a drawing.
I call a different sub with 2 centermarks as references.
But my loop stops after placing 1 break (when i do not display a messagebox).
But when I do display a messagebox for each time it loops, it loops just fine to the end.
I have tried for and while loops but get the same result.
How Could i resolve this so i don't get 50 message boxes when i try to get to the end of my loop.
And what could cause this behaviour for future reference ?
TL:DR how can I make my loop go to the end without the need of interaction through a messagebox.
  For  BreakCount As Integer = 0 To cmCollection.Count -2 Step 1
       		MsgBox(BreakCount) 'without this the loop ends after 1 break
		BreakBetweenCentermarks(ThisDoc.Document.ActiveSheet.DrawingViews(1), cmCollection.Item(BreakCount), cmCollection.Item(BreakCount + 1))
    Next BreakCount
Many thanks in advance
Curtis_Waguespack
Hi @loicLPQZG,
It's likely just a timing issue. The message box it providing a pause for the loop to finish processing.
You can try one of these.
Hope that helps,
Curtis
add a DoEvents line to allow it to process
For BreakCount As Integer = 0 To cmCollection.Count - 2 Step 1
    Application.DoEvents() ' Allow the application to process pending events
Next BreakCount
add a pause/delay
    System.Threading.Thread.Sleep(500) ' half second delay
Next BreakCount
loicLPQZG
This solved my issue, thank you very much.
for others i did have to put :
System.Windows.Forms.Application.DoEvents()
 Because the duality of 'Application'.
