Looking Rule to delete all Rules in ipt
Message 1 of 8
Hi all,
I am looking for help for the below requirement
I have few Inventor parts, using 'SaveCopyAs' command I am creating copy of all these files and saving it in separate folder.
I am looking for Rule that deletes all the Rules in the newly created Inventor part file (.ipt)
Any help will be greatly appreciated
Rudresh
Replies (7)
Message 2 of 8
LukeDavenport
Hi Rudresh,
You can do this manually with the below command
[image: Inline image 1]
Alternatively, here is a blog I wrote with an iLogic rule to delete all
rules in the active part (or assembly)
https://www.cadlinecommunity.co.uk/hc/en-us/articles/202020531-Inventor-2015-iLogic-Delete-All-iLogi...
Best regards,
Luke
Message 3 of 8
LukeDavenport
Sorry this was the command I was referring to.
Message 4 of 8
Thanks Luke,
I used the Logic that you have refferred, had to change some lines. It worked fine..
Rudresh
Message 5 of 8
b.mccarthy
Hello.
I also have need of this process, however, the link above is no longer valid (only 10+ years old. What's up with that???)
Can anyone who has this code, or similar, share it, please?
TIA
Message 6 of 8
jnowel
Message 7 of 8
b.mccarthy
@jnowel
Thank you, however, that rule appears to delete all rules in all components in an assembly, which is not what I need. I am looking to delete all rules at the part level.
I am sure that the @Andrii_Humeniuk code could be modified to run at the part level, but that is beyond my current skill level.
TIA
Message 8 of 8
jnowel
@b.mccarthy
Below line of code can do that and will only delete the rules on the ActiveDocument (it may be a part, assembly or drawing)
This will have to be ran as an external rule.
iLogicVb.Automation.DeleteAllRulesInDocument(ThisApplication.ActiveDocument)
Above line can be modified to only delete the rules if the ActiveDocument is a Part (and won't delete rules if it is a drawing or assembly)
Dim oDoc As Document = ThisApplication.ActiveDocument
If TypeOf oDoc Is PartDocument Then iLogicVb.Automation.DeleteAllRulesInDocument(oDoc)
